914Mels |
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California ![]() |
Does anyone have a source for the wire ends that go to the d jet injectors? I don't need the whole plastic end, just the wire connector with or with out the wire. I see standard motor product sells the whole thing but I'd rather buy just the connector itself.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Attached thumbnail(s) ![]() |
Mikey914 |
Should be 20% off til midnight. So if you do buy it before midnight pacific we will adjust it down 20% and refund it.
Mark |
914Mels |
Thanks for the fast reply. On another note, any idea when the perlon carpet kits will be back in stock?
Mikey914 |
We are working on a new upgraded version of these now. Will be ready in the next few weeks. PM me your contact info, I'll have Kenzie drop you a call when they are done.
914Mels |
Thanks
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Hey mark, how about spring clips for Bosch connectors on L-Jetronic?
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,094 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Mikey914 |
914Mels |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,963 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
DP
JeffBowlsby |
To be sure you know what you want, this is the D-Jet terminal
Attached image(s) ![]() |
JeffBowlsby |
And this is the L-Jet terminal. They are not interchangeable.
Van B |
I was picking up the thread since the OP got his question answered. I’m looking for the retaining clip, not connectors. The stainless wire box shaped clips that hold the plug together. I’m holding my AFM and CSV together with safety wire currently (IMG:style_emoticons/default/rolleyes.gif)
Lo-Fi Version | Time is now: 30th June 2025 - 07:51 PM |
