Ground Studs, Early v Late |
NARP74 |
Nov 30 2021, 12:16 PM
Senior Member Group: Members Posts: 1,048 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
My car had been wrecked in the past and had a new front end grafted on. Probably during its race years. When they put the new front end on, it did not have any ground studs where the headlights are.
As a fix, they just used a sheet metal screws for the ground and put it through the fender well. As a result, a couple ground wires are just floating in air not connected because they can not reach the sheet metal screw. I want to hook them up as they should be. Is there an early v late version of the ground studs and location? |
VaccaRabite |
Nov 30 2021, 02:26 PM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
There isn't a ground stud in the nose of the car. BUt the ground wires get looped into bolts and ground that way.
What wires are hanging free? Many of the headlight ground wires wires go to the bolt holes that hold the plastic covers for the headlight actuator arms. Zach |
NARP74 |
Nov 30 2021, 05:50 PM
There isn't a ground stud in the nose of the car. BUt the ground wires get looped into bolts and ground that way. What wires are hanging free? Many of the headlight ground wires wires go to the bolt holes that hold the plastic covers for the headlight actuator arms. Zach I have a pic of another 74 that has a bolt for a ground connection right by the headlights. The wires floating free on mine are both brown ground wires. |
NARP74 |
Dec 1 2021, 11:50 AM
This dropped fast. Anyone else?
Olympic 914 |
Dec 1 2021, 03:18 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
My '73 has Ground studs in the same place as pictured.
NARP74 |
Dec 1 2021, 03:26 PM
It's strange but my grafted on front end did not have the captive nut pockets for the fog lights either. Of course all of these issues were solved with sheet metal screws by the PO!
I'll have to look at some documentation to see if these were both traits of earlier cars. |
914e |
Dec 2 2021, 02:47 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Are you looking for these ground tabs? this is a 76
NARP74 |
Dec 3 2021, 12:22 PM
I guess I will just drill a hole and use a suitable bolt for the connection. I have to check for room for the headlight to pass though.
Does anyone know if either of these M6 or M8 round studs are the ones the factory used? https://www.restoration-design.com/store/category/HARD |
NARP74 |
Dec 14 2021, 11:59 AM
Found this from Bowlsby, don't know if it is year dependent. It does show what is connected in the front ground stud locations. I should be able to figure out what is not connected and get it hooked up.
https://bowlsby.net/914/Classic/zTN_Elect_GroundPoints.jpg |
Lo-Fi Version | Time is now: 20th April 2024 - 02:36 AM |
