Ground Studs, Early v Late |
NARP74 |
Nov 30 2021, 12:16 PM
Senior Member Group: Members Posts: 1,058 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
My car had been wrecked in the past and had a new front end grafted on. Probably during its race years. When they put the new front end on, it did not have any ground studs where the headlights are.
As a fix, they just used a sheet metal screws for the ground and put it through the fender well. As a result, a couple ground wires are just floating in air not connected because they can not reach the sheet metal screw. I want to hook them up as they should be. Is there an early v late version of the ground studs and location? |
NARP74 |
Dec 3 2021, 12:22 PM
I guess I will just drill a hole and use a suitable bolt for the connection. I have to check for room for the headlight to pass though.
Does anyone know if either of these M6 or M8 round studs are the ones the factory used? https://www.restoration-design.com/store/category/HARD |
Lo-Fi Version | Time is now: 5th May 2024 - 04:00 PM |
