914/6 Carb to Original FI |
mmascari |
Dec 1 2021, 05:55 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I have a 914/6 conversion with a 3.0l SC engine. I have installed PMO 46mm carbs and considering switching to fuel injection. I would prefer to use stock fuel injection. Has anyone had success installing 3.2l engine Fuel injection components on a 3.0 engine?
Steve |
Dec 1 2021, 06:27 PM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I have a 914/6 conversion with a 3.0l SC engine. I have installed PMO 46mm carbs and considering switching to fuel injection. I would prefer to use stock fuel injection. Has anyone had success installing 3.2l engine Fuel injection components on a 3.0 engine? I have only seen stock CIS injection on a 3.0 914-6 conversion. I would also post in the Pelican 911 technical forum. https://forums.pelicanparts.com/porsche-911-technical-forum/ I have seen some threads over there on the topic of using 3.2 DME injection in place of CIS injection |
Dec 1 2021, 06:43 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Quite a few done on pelican.
Search - motronic injection |
targa72e |
Dec 2 2021, 02:19 PM
Member Group: Members Posts: 256 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I did a SC 3.0 with 3.2 manifold and aftermarket programmable FI many years ago (20+). Pretty easy to do. The whole system is still installed and working on my friends car.
john |
pete-stevers |
Dec 2 2021, 02:31 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
If your PMOs are 40s send me a pm .. I might be interested
sorry... I just read 46s |
JmuRiz |
Dec 2 2021, 03:28 PM
914 Guru Group: Members Posts: 5,422 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Sounds like a good option, but be aware the prices on 3.2 intake manifolds are pretty high. I was thinking about something similar on my 2.7 build, but the price was too high for my budget.
mmascari |
Dec 2 2021, 05:14 PM
Sounds like a good option, but be aware the prices on 3.2 intake manifolds are pretty high. I was thinking about something similar on my 2.7 build, but the price was too high for my budget. Let me ask this. Will the stock 3.0 fuel injection components work on a motor that has JE pistons(10:1) and aggressive webcam cams or will it require a custom fuel/air map, therefore an aftermarket FI setup |
Dec 2 2021, 05:52 PM
Sounds like a good option, but be aware the prices on 3.2 intake manifolds are pretty high. I was thinking about something similar on my 2.7 build, but the price was too high for my budget. Let me ask this. Will the stock 3.0 fuel injection components work on a motor that has JE pistons(10:1) and aggressive webcam cams or will it require a custom fuel/air map, therefore an aftermarket FI setup Custom chip for the stock ecu. |
mmascari |
Dec 2 2021, 06:48 PM
Sounds like a good option, but be aware the prices on 3.2 intake manifolds are pretty high. I was thinking about something similar on my 2.7 build, but the price was too high for my budget. Let me ask this. Will the stock 3.0 fuel injection components work on a motor that has JE pistons(10:1) and aggressive webcam cams or will it require a custom fuel/air map, therefore an aftermarket FI setup Custom chip for the stock ecu. Great thanks. How do you map the programming for the Air/fuel on the chip? Are there people out there that can do that? |
gandalf_025 |
Dec 2 2021, 06:53 PM
Senior Member Group: Members Posts: 1,447 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
It is my understanding that the CIS can take more compression
but it is not great with much more cam.. I think 964 type cams will work and add a modest amount of power but I think the timing is critical.. |
JmuRiz |
Dec 2 2021, 11:41 PM
Sounds like a good option, but be aware the prices on 3.2 intake manifolds are pretty high. I was thinking about something similar on my 2.7 build, but the price was too high for my budget. Let me ask this. Will the stock 3.0 fuel injection components work on a motor that has JE pistons(10:1) and aggressive webcam cams or will it require a custom fuel/air map, therefore an aftermarket FI setup You mean stock 3.2 intake right? It should, check with Steve Wong at 911chips he can do a custom chip for the 3.2 intake and ecu. I think they used to have a bigger TB too. |
brant |
Dec 3 2021, 06:51 AM
914 Wizard Group: Members Posts: 11,607 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Sounds like a good option, but be aware the prices on 3.2 intake manifolds are pretty high. I was thinking about something similar on my 2.7 build, but the price was too high for my budget. Let me ask this. Will the stock 3.0 fuel injection components work on a motor that has JE pistons(10:1) and aggressive webcam cams or will it require a custom fuel/air map, therefore an aftermarket FI setup The cis will not be able to accept your cams Too aggressive |
ClayPerrine |
Dec 3 2021, 07:32 AM
Life's been good to me so far..... Group: Admin Posts: 15,394 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Use the stock CIS intake and throttle body. Put EFI on it.
Here is a link to the kit to do it. https://www.bitzracing.com/products/Partial_EFI_KIT/ (IMG:http://www.914world.com/bbs2/uploads_offsite/www.bitzracing.com-1143-1638538326.1.jpg) This is designed to replace the CIS on a 911 with EFI. It should be easy to find the CIS intake hard parts. Hope this helps. Clay |
mmascari |
Dec 3 2021, 10:08 AM
Use the stock CIS intake and throttle body. Put EFI on it. Here is a link to the kit to do it. https://www.bitzracing.com/products/Partial_EFI_KIT/ (IMG:http://www.914world.com/bbs2/uploads_offsite/www.bitzracing.com-1143-1638538326.1.jpg) This is designed to replace the CIS on a 911 with EFI. It should be easy to find the CIS intake hard parts. Hope this helps. Clay Would that setup work with a 3.2 manifold? Seems like it would work with any manifold? If so, would I use the stock 3.2 throttle body? |
ClayPerrine |
Dec 3 2021, 11:00 AM
Use the stock CIS intake and throttle body. Put EFI on it. Here is a link to the kit to do it. https://www.bitzracing.com/products/Partial_EFI_KIT/ (IMG:http://www.914world.com/bbs2/uploads_offsite/www.bitzracing.com-1143-1638538326.1.jpg) This is designed to replace the CIS on a 911 with EFI. It should be easy to find the CIS intake hard parts. Hope this helps. Clay Would that setup work with a 3.2 manifold? Seems like it would work with any manifold? If so, would I use the stock 3.2 throttle body? Yes, it would work with the 3.2 manifold. But they are harder to find, and CIS heads may need an adapter to work with the 3.2 manifold. I am not 100% sure on that though. Plus... the CIS manifolds, plenum, and throttle body are readily available and cheaper than the 3.2 motronic manifolds. Clay |
Luke M |
Dec 3 2021, 11:02 AM
Senior Member Group: Members Posts: 1,368 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I was planning on running a 3.2 EFI on my brothers 3.0 but went with the Weber 40ida instead. One reason was it looks period correct. Yeah carbs can be a pain to tune and keep in tune. Here's the deal with the Carrera intake install. You will need manifold to head adapters. Turbo craft sells them for around $275 for the set. If you can get your hands on a good used intake more then likely you will need to replace some of the injection lines. Look up the prices they are nuts. The injectors you'll need depends on the engine combo. New efi pump and lines to and from tank. Don't forget the sensors you need to install to make it all work. Depending on your trans a mod to the bell housing for the sensors. Engine management is another thing. You can run the stock motronic and have a custom chip made or get another system. Either way it's not cheap and I'm sure I'm forgetting a few other misc things that need to be done. So you get my drift why we went with the Webers yet? Look at spending well over 3 grand on the low end to make it all work. The kit that Clay posted maybe your best bet if you want to get away from the carbs. Depending on your head ports you'll need either small or large port manifolds for the cis. My brother's 3.0 seams to be similar to your combo but he's running 40ida Webers. I drove the car and seamed to perform well. I was doing 2nd gear burn outs without a problem. Now his dizzy isn't re-curved yet either so I'm sure there's a few horses left there.
Why are you running 46's? I feel the 40's work well on my brothers 3.0 . You happen to know your head port size? |
mmascari |
Dec 3 2021, 11:22 AM
I was planning on running a 3.2 EFI on my brothers 3.0 but went with the Weber 40ida instead. One reason was it looks period correct. Yeah carbs can be a pain to tune and keep in tune. Here's the deal with the Carrera intake install. You will need manifold to head adapters. Turbo craft sells them for around $275 for the set. If you can get your hands on a good used intake more then likely you will need to replace some of the injection lines. Look up the prices they are nuts. The injectors you'll need depends on the engine combo. New efi pump and lines to and from tank. Don't forget the sensors you need to install to make it all work. Depending on your trans a mod to the bell housing for the sensors. Engine management is another thing. You can run the stock motronic and have a custom chip made or get another system. Either way it's not cheap and I'm sure I'm forgetting a few other misc things that need to be done. So you get my drift why we went with the Webers yet? Look at spending well over 3 grand on the low end to make it all work. The kit that Clay posted maybe your best bet if you want to get away from the carbs. Depending on your head ports you'll need either small or large port manifolds for the cis. My brother's 3.0 seams to be similar to your combo but he's running 40ida Webers. I drove the car and seamed to perform well. I was doing 2nd gear burn outs without a problem. Now his dizzy isn't re-curved yet either so I'm sure there's a few horses left there. Why are you running 46's? I feel the 40's work well on my brothers 3.0 . You happen to know your head port size? Maybe it would be easier to just trade my 46s for 40s, would be easier replacement. Anyone want to trade? |
Luke M |
Dec 3 2021, 11:37 AM
I was planning on running a 3.2 EFI on my brothers 3.0 but went with the Weber 40ida instead. One reason was it looks period correct. Yeah carbs can be a pain to tune and keep in tune. Here's the deal with the Carrera intake install. You will need manifold to head adapters. Turbo craft sells them for around $275 for the set. If you can get your hands on a good used intake more then likely you will need to replace some of the injection lines. Look up the prices they are nuts. The injectors you'll need depends on the engine combo. New efi pump and lines to and from tank. Don't forget the sensors you need to install to make it all work. Depending on your trans a mod to the bell housing for the sensors. Engine management is another thing. You can run the stock motronic and have a custom chip made or get another system. Either way it's not cheap and I'm sure I'm forgetting a few other misc things that need to be done. So you get my drift why we went with the Webers yet? Look at spending well over 3 grand on the low end to make it all work. The kit that Clay posted maybe your best bet if you want to get away from the carbs. Depending on your head ports you'll need either small or large port manifolds for the cis. My brother's 3.0 seams to be similar to your combo but he's running 40ida Webers. I drove the car and seamed to perform well. I was doing 2nd gear burn outs without a problem. Now his dizzy isn't re-curved yet either so I'm sure there's a few horses left there. Why are you running 46's? I feel the 40's work well on my brothers 3.0 . You happen to know your head port size? Maybe it would be easier to just trade my 46s for 40s, would be easier replacement. Anyone want to trade? Before you start trading. Why are you wanting to get away from the 46's? What's your engine combo with head port size? 40's maybe your best bet but answer these questions 1st. |
gandalf_025 |
Dec 3 2021, 11:47 AM
This engine has been in my wife’s 911 for a number of years..
It was initially built to increase HP and still be able to pass California Emissions. It was built by Ralph Meaneys engine builder in Massachusetts back in the day and lived in California for a number of years. It is back in Massachusetts now and still runs well.. For what it is worth…??? |
ClayPerrine |
Dec 3 2021, 01:02 PM
This engine has been in my wife’s 911 for a number of years.. It was initially built to increase HP and still be able to pass California Emissions. It was built by Ralph Meaneys engine builder in Massachusetts back in the day and lived in California for a number of years. It is back in Massachusetts now and still runs well.. For what it is worth…??? Love the twin plug! How easy is it to get a cap and rotor set for it? Clay |
Lo-Fi Version | Time is now: 20th April 2024 - 01:34 AM |
