914/6 Carb to Original FI |
Dec 3 2021, 01:12 PM
I don’t know why everyone says the 3.2 manifolds are expensive or hard to get. I’ve sold plenty for $500 and a wtb on pelican will get you a pair.
ClayPerrine |
Dec 3 2021, 02:21 PM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I don’t know why everyone says the 3.2 manifolds are expensive or hard to get. I’ve sold plenty for $500 and a wtb on pelican will get you a pair. That may be true.. but using the CIS intake means not having to purchase the intake adapters to make the 3.2 intake work with CIS heads. That saves $275.00. Here's the deal with the Carrera intake install. You will need manifold to head adapters. Turbo craft sells them for around $275 for the set. Clay |
Luke M |
Dec 3 2021, 02:26 PM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I don’t know why everyone says the 3.2 manifolds are expensive or hard to get. I’ve sold plenty for $500 and a wtb on pelican will get you a pair. The problem is getting everything else to go with the manifold. Most fuel lines are shot by now. New replacement fuel lines will cost you around $650. I don't care either way if one wants to use a 3.2 intake. Just making them aware of the hidden cost that follows. I went down that road and it turned out to be too expensive. I ended up selling my manifold in 2017 for $900.. As for the op lmk your engine setup. I can look up the jetting I used in my brothers carbs if that helps you. |
ClayPerrine |
Dec 3 2021, 02:35 PM
I will admit.. I am biased. I hate carburetors. Not just a little bit, but a LOT.
The funny part is that the factory six we have has Webers on it. So I have to maintain them. (IMG:style_emoticons/default/mad.gif) I prefer an EFI system over carbs any day. Easier cold start, easier to drive, and much easier to maintain. Go up and down a mountain without having to stop halfway up and halfway down to change jets. No fuel smell in the garage from bowl vents. No having to pump the accelerator to get enough fuel to make the car start. There is a reason no new cars are built with carburetors. Same reason we don't use external band drum brakes or wooden wheels anymore. Obsolete tech. Clay |
mmascari |
Dec 3 2021, 02:43 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I don’t know why everyone says the 3.2 manifolds are expensive or hard to get. I’ve sold plenty for $500 and a wtb on pelican will get you a pair. The problem is getting everything else to go with the manifold. Most fuel lines are shot by now. New replacement fuel lines will cost you around $650. I don't care either way if one wants to use a 3.2 intake. Just making them aware of the hidden cost that follows. I went down that road and it turned out to be too expensive. I ended up selling my manifold in 2017 for $900.. As for the op lmk your engine setup. I can look up the jetting I used in my brothers carbs if that helps you. It is a 3.0l with JE Pistons (10:1), webcam 502/104 grind. The heads have the larger intake size(can't remember the exact size). Then the 46 PMOs. Again, when driving under 3k RPM it tends to sputter but once 3K hits it is fine |
targa72e |
Dec 3 2021, 05:18 PM
Member Group: Members Posts: 258 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I am with Clay I hate carbs as well. Your problem sound like a tuning issue. If you decide to go with fuel injection couple things.
The adapters that have been mentioned are for running a 3.2 manifold on a Turbo motor with stock small 32mm inkakes . The intake on the 3.0 big port and 3.2 head are almost the same. 3.0 39mm 3.2 41mm and adaptors are not required. 3.2 head big port 3.0 The indent for the fuel injector is a slightly different shape between 3.0 and 3.2. I gasket matched the 3.0 head to the 3.2 gasket with a dremel and bolted the intake directly to the head. The main difference between 3.0 and 3.2 is the intake port height is different between a 3.0 and 3.2 head (beside port size) is the 3.2 is shorter and there is a thick (about 1/4" thick) gasket that goes between the manifold and head in stock application. To use the complete 3.2 fuel injection system on a 3.0 is difficult. It would require complete rebuild of the motor, head machining for Temp sensor and 3.2 flywheel. The distributor on the 3.2 rotates the opposite direction of the 3.0 and would require changing the gear on the crank to use 3.2 distributor on 3.0. The 3.2 distributor does not have any trigger or advance mechanisms as the advance is controlled by the ECU and the trigger is from a sensor that reads the teeth on the 3.2 flywheel to provide speed and possition information to the ECU. Temperature sensor screws into 3.2 cylinder head. It is much easier to use a aftermarket ECU. You can feed engine RPM information to the aftermarket system from the trigger wheel in the SC distributor (or use tach signal). In my conversion I used the factory 3.2 manifold, throttle body (modified to include Throttle position sensor), fuel rails, injectors and lines. ECU was aftermarket. Had to add the TPS, Map sensor, intake air sensor, O2 sensor and Engine temp sensor, these were all GM parts on my conversion. I used the SC idle air bybass for fast cold idle. If you still have the SC intake the blitz system is a pretty complete kit for conversion to EFI. john |
Luke M |
Dec 3 2021, 06:12 PM
I don’t know why everyone says the 3.2 manifolds are expensive or hard to get. I’ve sold plenty for $500 and a wtb on pelican will get you a pair. The problem is getting everything else to go with the manifold. Most fuel lines are shot by now. New replacement fuel lines will cost you around $650. I don't care either way if one wants to use a 3.2 intake. Just making them aware of the hidden cost that follows. I went down that road and it turned out to be too expensive. I ended up selling my manifold in 2017 for $900.. As for the op lmk your engine setup. I can look up the jetting I used in my brothers carbs if that helps you. It is a 3.0l with JE Pistons (10:1), webcam 502/104 grind. The heads have the larger intake size(can't remember the exact size). Then the 46 PMOs. Again, when driving under 3k RPM it tends to sputter but once 3K hits it is fine My brother has the same p/c's, webcam 120/104 , heads are 3.0 euro/big port (39 mm intake/35 mm exh) , and Weber 40 ida. Carbs are setup as follows : 36mm venturi short aux venturi 155 mains F3 emulsion tubes 170 main air correction jets 60 idle fuel jets 50 accelerator squirter jets It's been a while but pretty sure this was what Paul at Performance Oriented recommended. You maybe able to re jet your 46's but not 100% if that'll work. I believe Paul has retired from the carb business but try over on Pelican site as he may answer. His user name there is 1QuickS . |
Dec 3 2021, 06:32 PM
I have a 3.0 case and crank but I’m going to use 3.2 p&c’s and 3.2 heads to make a 3.2 short stroke. Not sure on induction yet. Maybe a 3.2 intake with VEMS engine management.
3.2 tip - you can get your fuel lines rebuilt for about $250. |
jim dorociak |
Dec 6 2021, 10:03 AM
Member Group: Members Posts: 95 Joined: 23-January 09 From: Newbury Park, Ca Member No.: 9,966 Region Association: Southern California |
short stoke 3.2 means 98mm pistons and bored out 95mm cylinders and the 70.4mm crankshaft. been thinking about this same build. Jim
Lo-Fi Version | Time is now: 25th April 2024 - 03:04 PM |
