Whats the best tool you ever acquired |
pfreiburger |
Dec 5 2021, 01:03 AM
Member Group: Members Posts: 109 Joined: 6-October 20 From: Fond du Lac, WI Member No.: 24,738 Region Association: None |
I really like my Evolution 14” metal cut off saw, which I have owned it for about 3 years. Unlike most chop saws it uses a toothed rather than abrasive blade. The cuts are cleaner and the saw is cleaner in operation, producing MUCH less dust than an abrasive blade chop saw – actually more chips than anything. The only downside is that the blades are expensive ($80 & up) but they promise a 1000 cut life – in my experience that is probably accurate as I am still on my first blade and it will cut ½” stock clean & quick. The newer versions have detail refinements and are even better. I would buy one again for sure.
Shivers |
Dec 5 2021, 04:52 AM
Senior Member Group: Members Posts: 2,356 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
My
flyer86d |
Dec 5 2021, 04:04 PM
Member Group: Members Posts: 422 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
My Bosch 4 1/2 inch angle grinder. I burned out 2 Black and Decker units building my car trailer in 1986. I bought the Bosch unit to complete the project and then used it for 10 years in the commercial garage business and still have it today restoring old Porsche’s in the barn.
Charlie |
mbseto |
Dec 5 2021, 11:29 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
#1 - Big Bertha, the Bosch hammer drill I use to set bolts in rock for rock climbing.
#2 - Large Marge, the 3hp pneumatic angle grinder that I got at auction for 10 bucks. More power than my push mower. The manufacturer still makes rebuild kits, so the internals are all cherry again. #3 - As yet unnamed Stanley #7 jack plane, found at a garage sale. Put an atom-splitting edge on the iron and still need to come up with a job big enough to need it. But if anyone ever breaks in to my house and I have that plane at hand, all they will get back is a big damp pile of a billion one-cell-thick anatomically correct slices. |
VaccaRabite |
Dec 6 2021, 07:01 AM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
This is a hard question.
The tool that has made me the most money is my Delta wood lathe. The tool that made restoring cars easiest is probably the 60 gallon air compressor - though with good battery op tools I'm using less air these days. I have a lot of nice tools, but those two are the backbone of my wood shop and restoration bay. Zach |
pt_700 |
Dec 6 2021, 06:32 PM
Senior Member Group: Members Posts: 1,090 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
if the jis drivers fail, i like these (before resorting to an ez-out;
https://www.engineertools-jp.com/pz6465 |
Steve |
Dec 6 2021, 06:48 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
My scissor lift.
Gatornapper |
Dec 6 2021, 07:07 PM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
My John Deere 5045E
(IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1638839229.1.JPG) Used for a thousand things on our 20 acres and maintaining our 1/2 mile drive (through neighbors property). Also good once for lifting rear of 914 - as if it were a 2x4......... But I think I'd give the impact driver a 2nd - but it's a long way from the tractor....... GN |
lesorubcheek |
Dec 6 2021, 07:21 PM
Member Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
This is a question that is virtually impossible to have only one answer, but for removing tough screws, an impact driver has probably saved the most aggravation. Combo of kroil, or acetone/ATF soaking and a heat gun along with the impact driver has made life much easier than before. Here's a stock pic from amazon.
Dan |
carr914 |
Dec 7 2021, 07:45 AM
Racer from Birth Group: Members Posts: 118,206 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
my 4 Post Lift
carr914 |
Dec 7 2021, 07:56 AM
Mark Henry |
Dec 7 2021, 08:14 AM
My two post lift. Best money I ever spent. No laying in the cat litter anymore. (IMG:style_emoticons/default/agree.gif) I would have been done years ago, I can't lay on the cold cement floor even though my shop has full heat. |
Quinn Moore |
Dec 7 2021, 08:43 AM
Qmoore Group: Members Posts: 106 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
Superhawk996 |
Dec 7 2021, 09:14 AM
914 Guru Group: Members Posts: 5,754 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I don't know which is the best tool I've ever acquired for sure.
I can't decide between my small 8x19" Jet lathe or my 1950's era South Bend vertical knee mill. If I have to choose just one, it's the lathe. A lathe can be used to machine all the parts needed to reproduce itself or even a mill (possible in theory but very difficult in practice). So I guess I have to go with the lathe. The lathe makes modification of screws, bolts, washers/spacers, etc., so simple that I simply can't imagine living without it after having it for the last 20 years or so. |
ddire333 |
Dec 7 2021, 10:30 AM
Member Group: Members Posts: 91 Joined: 2-November 20 From: ireland Member No.: 24,835 Region Association: Europe |
IronHillRestorations |
Dec 7 2021, 01:12 PM
I don't have pictures, and not my best tool, but about 20 years ago I got a set of Stahlwille metric screwdrivers. When I first got them, I thought the handles felt kind of cheap, but they've held up well. There's a difference between SAE and metric screwdrivers and these have been great. They have a hex section on the shank just below the handle that you can put a wrench on for more torque.
SKL1 |
Dec 7 2021, 02:10 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
My John Deere 5045E (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1638839229.1.JPG) Used for a thousand things on our 20 acres and maintaining our 1/2 mile drive (through neighbors property). Also good once for lifting rear of 914 - as if it were a 2x4......... But I think I'd give the impact driver a 2nd - but it's a long way from the tractor....... GN I don't think that picture was taken in Florida... or in gator country! Looks more Minnesota or my home state of Iowa... |
Porschef |
Dec 7 2021, 05:27 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Great gun, although the fuel and fasteners are pricey
KELTY360 |
Dec 7 2021, 07:49 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
My antique Plumb war finish combination 1/2” speed wrench and breaker bar. Bought at estate sale over 30 years ago for $3.00. Great for running lug nuts in and tightening. Breaks loose impossible nuts easily. Has swivel head and rotating handle. It’s been a reliable answer to many situations.probably manufactured in mid-1940’s. Lives in the 914.
Front yard mechanic |
Dec 7 2021, 09:16 PM
Senior Member Group: Members Posts: 1,155 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Hehe he said tool
Lo-Fi Version | Time is now: 28th April 2024 - 12:45 AM |
