problemswith the fan belt, wont stay on |
bernbomb914 |
Jul 28 2005, 08:32 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I am having trouble keeping my fan belt on. It comes off as soon as you rev the engine. The alignment looks as good as my old engine. You cant move the alt back any furtheras there is no room. What am I missing here What majic wand do I have to have to cure it.
Bernie |
bd1308 |
Jul 28 2005, 08:40 PM
new belt.
bernbomb914 |
Jul 28 2005, 08:42 PM
how about 3 new belts.
Joe Bob |
Jul 28 2005, 08:49 PM
Pulley, shims and/or tension...
John |
Jul 28 2005, 11:19 PM
I will just assume that we are talking 914-4.
The last time I saw this happen, we found that somebody had put the alternator pully on BACKWARDS. The notches should face away from the alternator body. This was enough of a misalignment that it caused the belt to jump off as soon as the engine speed was increased much above idle. We checked all the alternator bolts and found them all tight and finally took a peek at the pully itself. Good luck. |
tesserra |
Jul 28 2005, 11:26 PM
Member Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 |
Johnman beat me to it. I drove me crazy and on top of that it was on a smogged '76, so I had to deal with the smog pump bracket/[pulley.
Did not realize the pulley was on backwards until the motor was out for some oil leak work. DAPO |
Jake Raby |
Jul 28 2005, 11:27 PM
Alignment...
Do you have two yardsticks???? If so you can use them to place in each belt groove at the top and bottom and adjust the alignment so the two touch when the alignment is correct... Its kinda tough in the car due to space limitations- we do it on the dyno on every engine that gets a DTM or stock sheetmetal... Took one to 7,800 today running the belt and she hasn't popped off yet.. The yardsticks work well, you cannot "Eyeball" these adjustments. |
bernbomb914 |
Jul 29 2005, 09:56 AM
if I put the pully on like you say it locks up. is there a shim kit for this to move it away from the alt. or should I try wshers?
bernie |
Jake Raby |
Jul 29 2005, 09:59 AM
The entire alternator moves to correct the adjustment. The bracket that holds the alternator to the shroud has elongated holes and two 13mm bolts. Loosen them and move the alternator fore and aft till proper geometry is achieved.
bernbomb914 |
Jul 29 2005, 10:04 AM
been there done that
Bernie |
john rogers |
Jul 29 2005, 10:45 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
If it were me, I'd check the fore/aft alignment between the two pulleys with a steel straight edge. Then I would use a dial indicator and check each pulley at the outer edge for both radial and axial trueness. Then I'd check the alt shaft end play and check the crank end play. Last of all is the belt the right type and the edges of the belt sitting against the V of the pulleys as it should? Good luck.
Lo-Fi Version | Time is now: 16th May 2024 - 08:36 AM |
