6 Pages V  1 2 3 > »
> Group buy for door panels These close out 8/31/22 Thanks all!, Plaid option TBD -Door panel clips and rubber door guides EVEN butyl for barrier!
Mikey914
post Dec 17 2021, 04:45 PM
The rubber man
Yes im making parts faster than we can get them listed. Just got these bad boys done.
What you are looking at it a correct style early metal bolster top and OEM style door cards.
Also made some new door pockets that fit perfectly onto the top band of the smugglers box on the driver's side.as well as the passenger side lower sections.
We made these out of plastic. Will be offering these up too.
Lastly found some vinyl in Germany that is close to the original pattern. We will be still stamping the correct versions. They are just significantly more expensive.
Thinking we can offer up a Group buy for plug and play door cards in the most complete form,.
Good news is that the fiberboard is less expensive and easier to work with, so we will be able to offer up some great pricing.
I anticipate bringing these to GB by end of January.
Will jave the white, black, brown and tan panels ready to ho soon.
Ill post up more pics and finalize the GB price after Christmas.
So who's interested?
Mark
Luke M
post Dec 17 2021, 04:59 PM
Mark,
I thought you sold a fiberglass or plastic backing for the door panels?
If so could that be a upgrade option?
I need a set so lmk on this.
Thanks,
jim_hoyland
post Dec 17 2021, 05:20 PM
Get that VIN ?
I like the tan door cards…. (IMG:style_emoticons/default/smile.gif)
Mikey914
post Dec 17 2021, 06:44 PM
The rubber man
QUOTE(Luke M @ Dec 17 2021, 03:59 PM) *
Mark,
Thanks,
We moved from the fiberglass to plastic. The material has gotten more expensive and we have to do large runs of it hand cutting the panels this process allows us to make much easier and will be more OEM. We will still carry the premium product, but if you don’t get your door panels soaked these are a great way to save some
That and we are trying to help keep the prices down as much as we can, so it’s more affordable to restore these cars!
Chaznaster
post Dec 17 2021, 09:21 PM
Definitely interested …
DRPHIL914
post Dec 18 2021, 10:01 AM
Dr. Phil
@Mikey914
i would be in for a set, brown probably, but, question: do you have any scrap tartan material? id like to do a set of door cards with top edge vinyl just like these but lower in tartan(either orange targan or black/white).
Phil
Mikey914
post Dec 18 2021, 05:01 PM
The rubber man
QUOTE(DRPHIL914 @ Dec 18 2021, 08:01 AM) *
@Mikey914
Phil
I don't have any scraps that big, but we could look at doing up a set that way you get only what you need. Let me know your final choice and I'll do one up.
Mark
theer
post Dec 18 2021, 08:38 PM
In in for a couple door pockets and pass side under-thingys. Two of each, please.
djway
post Dec 18 2021, 08:50 PM
jim_hoyland
post Dec 20 2021, 05:21 PM
Get that VIN ?
I’m looking to replace both door interior panels in Tan and replacing the arm rests. Plus I’ll need new window winders.
Well the food cards be covered?or do I have to do that ?
@Mikey914
Mikey914
post Dec 21 2021, 05:47 PM
The rubber man
SO you will notice the cage nuts are preinstalled for the passenger side door panels
All holes are precut, and the winder and door handle areas are precut. making these easy to install.
My 1st set out of the gate
-The door pockets will be available shortly. I will do a separate GB so you don't have to buy my panels to get them
The brown and tan are a little more expensive as we had to import material.
Can do the late style vinyl also they will still fit.
bdstone914
post Dec 21 2021, 06:09 PM
bdstone914
@mikey914
Are you making both early and late door cards? The early cards are smaller and show part of the door when it is closed.
Mikey914
post Dec 21 2021, 06:14 PM
The rubber man
The plastic are the late style, the early ones are made just like the early, they are interchangeable.
post Dec 21 2021, 09:23 PM
Will my existing arm rests and map pockets fit these? Also, I'm not clear on your above statement re: plastic door cards. I thought these were the fiber material pictured???
Mikey914
post Dec 21 2021, 09:25 PM
The rubber man
QUOTE(76-914 @ Dec 21 2021, 07:23 PM) *
Yes.
post Dec 21 2021, 09:31 PM
OK. I'm up for a set in black
windforfun
post Dec 21 2021, 09:35 PM
Please enlarge the pics to show the three top upward pointing mounting clips.
Mikey914
post Dec 21 2021, 11:40 PM
The rubber man
You can’t see much with the vinyl attached. What is it you want to see?
Does this help? May be easier to see without anything attached?
The second file is big enough you can zoom in.
JeffBowlsby
post Dec 22 2021, 12:03 AM
Hey Mark, do you have the complete upholstered door cards in early black brick mold available now? I don’t see them listed on your site.
DRPHIL914
post Dec 22 2021, 07:13 AM
Dr. Phil
QUOTE(DRPHIL914 @ Dec 18 2021, 11:01 AM) *
@Mikey914
i would be in for a set, brown probably, but, question: do you have any scrap tartan material? id like to do a set of door cards with top edge vinyl just like these but lower in tartan(either orange tartan or black/white).
Phil
@Mikey914
send me a PM on price and we'll work it out.
6 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 26th October 2026 - 07:44 PM
