Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Yes im making parts faster than we can get them listed. Just got these bad boys done.
What you are looking at it a correct style early metal bolster top and OEM style door cards. Also made some new door pockets that fit perfectly onto the top band of the smugglers box on the driver's side.as well as the passenger side lower sections. We made these out of plastic. Will be offering these up too. Lastly found some vinyl in Germany that is close to the original pattern. We will be still stamping the correct versions. They are just significantly more expensive. Thinking we can offer up a Group buy for plug and play door cards in the most complete form,. Good news is that the fiberboard is less expensive and easier to work with, so we will be able to offer up some great pricing. I anticipate bringing these to GB by end of January. Will jave the white, black, brown and tan panels ready to ho soon. Ill post up more pics and finalize the GB price after Christmas. So who's interested? Mark Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() Attached image(s) ![]() ![]() ![]() |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,416 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Mark,
I thought you sold a fiberglass or plastic backing for the door panels? If so could that be a upgrade option? I need a set so lmk on this. Thanks, |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,815 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I like the tan door cards…. (IMG:style_emoticons/default/smile.gif)
Attached image(s) ![]() |
Mikey914 |
Mark, I thought you sold a fiberglass or plastic backing for the door panels? If so could that be a upgrade option? I need a set so lmk on this. Thanks, We moved from the fiberglass to plastic. The material has gotten more expensive and we have to do large runs of it hand cutting the panels this process allows us to make much easier and will be more OEM. We will still carry the premium product, but if you don’t get your door panels soaked these are a great way to save some $$$ That and we are trying to help keep the prices down as much as we can, so it’s more affordable to restore these cars! |
Chaznaster |
Member ![]() ![]() Group: Members Posts: 325 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States ![]() ![]() |
Definitely interested …
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,830 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
@Mikey914
i would be in for a set, brown probably, but, question: do you have any scrap tartan material? id like to do a set of door cards with top edge vinyl just like these but lower in tartan(either orange targan or black/white). Phil |
Mikey914 |
@Mikey914 i would be in for a set, brown probably, but, question: do you have any scrap tartan material? id like to do a set of door cards with top edge vinyl just like these but lower in tartan(either orange targan or black/white). Phil I don't have any scraps that big, but we could look at doing up a set that way you get only what you need. Let me know your final choice and I'll do one up. Mark |
theer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States ![]() ![]() |
In in for a couple door pockets and pass side under-thingys. Two of each, please.
djway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California ![]() |
jim_hoyland |
I’m looking to replace both door interior panels in Tan and replacing the arm rests. Plus I’ll need new window winders.
Well the food cards be covered?or do I have to do that ? @Mikey914 |
Mikey914 |
SO you will notice the cage nuts are preinstalled for the passenger side door panels
All holes are precut, and the winder and door handle areas are precut. making these easy to install. My 1st set out of the gate -The door pockets will be available shortly. I will do a separate GB so you don't have to buy my panels to get them The brown and tan are a little more expensive as we had to import material. Can do the late style vinyl also they will still fit. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,035 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@mikey914
Are you making both early and late door cards? The early cards are smaller and show part of the door when it is closed. |
Mikey914 |
The plastic are the late style, the early ones are made just like the early, they are interchangeable.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,738 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Will my existing arm rests and map pockets fit these? Also, I'm not clear on your above statement re: plastic door cards. I thought these were the fiber material pictured???
Mikey914 |
76-914 |
OK. I'm up for a set in black
windforfun |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,057 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() ![]() |
Please enlarge the pics to show the three top upward pointing mounting clips.
Mikey914 |
You can’t see much with the vinyl attached. What is it you want to see?
Does this help? May be easier to see without anything attached? The second file is big enough you can zoom in. Attached thumbnail(s) ![]() ![]() |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,974 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Hey Mark, do you have the complete upholstered door cards in early black brick mold available now? I don’t see them listed on your site.
DRPHIL914 |
Lo-Fi Version | Time is now: 13th July 2025 - 03:06 AM |
