Group buy for door panels These close out 8/31/22 Thanks all!, Plaid option TBD -Door panel clips and rubber door guides EVEN butyl for barrier! |
Mikey914 |
Dec 17 2021, 04:45 PM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes im making parts faster than we can get them listed. Just got these bad boys done.
What you are looking at it a correct style early metal bolster top and OEM style door cards. Also made some new door pockets that fit perfectly onto the top band of the smugglers box on the driver's side.as well as the passenger side lower sections. We made these out of plastic. Will be offering these up too. Lastly found some vinyl in Germany that is close to the original pattern. We will be still stamping the correct versions. They are just significantly more expensive. Thinking we can offer up a Group buy for plug and play door cards in the most complete form,. Good news is that the fiberboard is less expensive and easier to work with, so we will be able to offer up some great pricing. I anticipate bringing these to GB by end of January. Will jave the white, black, brown and tan panels ready to ho soon. Ill post up more pics and finalize the GB price after Christmas. So who's interested? Mark Attached thumbnail(s) Attached image(s) |
Mikey914 |
Dec 30 2021, 10:38 AM
Well, trying to get some back stock on these so the waiting is minimal.
I went off on my own path again. Wound up taking more material than I thought it should as to mirror the pattern. Because of pattern having 2 small and 1 wide stripe I had to cut and flip it making me use about 1.25 yards. Yes, I have some drop, and if I did more it gets more efficient, but ouch. The material is a little finicky to work with. you can't stretch it much or it distorts the pattern, but you have to pull it straight to make the lines look good. What do you think?? Now I wonder what the pockets would look like if I can make them look good? Attached thumbnail(s) Attached image(s) |
Gary |
Dec 31 2021, 08:46 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Well, trying to get some back stock on these so the waiting is minimal. I went off on my own path again. Wound up taking more material than I thought it should as to mirror the pattern. Because of pattern having 2 small and 1 wide stripe I had to cut and flip it making me use about 1.25 yards. Yes, I have some drop, and if I did more it gets more efficient, but ouch. The material is a little finicky to work with. you can't stretch it much or it distorts the pattern, but you have to pull it straight to make the lines look good. What do you think?? Now I wonder what the pockets would look like if I can make them look good? Hi Mike, I'd be interested in this set w/ or /w'out pockets. I have GT style door pulls, so only need the cutout for the door release handle. Gary |
Lo-Fi Version | Time is now: 29th March 2024 - 06:37 AM |
