WTB Weltmeister Lower pivot & plate, Short shifter parts for Late shifter |
Cairo94507 |
Dec 21 2021, 07:35 PM
Michael Group: Members Posts: 9,758 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Hi all- Well after being without Internet for 8 days (thanks a lot Sudden Link) I am back and looking for a Weltmeister Short Shifter lower pivot and plate to go with my newly installed late stock shifter. So all you guys who yanked them out and went with the Renn Shifter, let me know you if you want to sell your Weltmeister part.
Thanks and Merry Christmas- Michael (IMG:style_emoticons/default/beerchug.gif) |
Shivers |
Jan 7 2022, 07:04 AM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I am making my 72 a side shift. I already have the earlier short shift kit, was thinking of grinding the sides of the ball flat, drill a hole to mount it to the second piece. Ha, with my budget I need to grow rubber trees, I'll post if it works
Montreal914 |
Jan 7 2022, 02:38 PM
Senior Member Group: Members Posts: 1,558 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I am making my 72 a side shift. I already have the earlier short shift kit, was thinking of grinding the sides of the ball flat, drill a hole to mount it to the second piece. Ha, with my budget I need to grow rubber trees, I'll post if it works @Shivers That would probably work although at a reduced side bearing surface. You might want to measure the distance between the half sphere to the hole on a side shifter as the whole bottom section might be longer on the side than it is on the tail. Or you could also weld a new piece at the end of your tail shifter. I was exploring that option with a cheap Mustang shifter that has the springs to bring the shifter back in the middle (2-3) plane. Plenty of options when you start to be creative! (IMG:style_emoticons/default/smash.gif) |
Shivers |
Jan 7 2022, 04:52 PM
I am making my 72 a side shift. I already have the earlier short shift kit, was thinking of grinding the sides of the ball flat, drill a hole to mount it to the second piece. Ha, with my budget I need to grow rubber trees, I'll post if it works @Shivers That would probably work although at a reduced side bearing surface. You might want to measure the distance between the half sphere to the hole on a side shifter as the whole bottom section might be longer on the side than it is on the tail. Or you could also weld a new piece at the end of your tail shifter. I was exploring that option with a cheap Mustang shifter that has the springs to bring the shifter back in the middle (2-3) plane. Plenty of options when you start to be creative! (IMG:style_emoticons/default/smash.gif) Some good stuff, thank you once I grind it, I guess I could hard face it and grind, file and sand it smooth on the sides. Worth a try, I have a side shifter to use as a template. If it doesn't work I have a stock one. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:30 AM |
