FS: Powder Coated ECU brackets $75 shipped |
bdstone914 |
Dec 22 2021, 12:09 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
These are the two ECU brackets that are used on D Jet engines 1970-74. The 75-76 cars had the bracket spot welded to the front battery tray edge. If you have replaced the battery tray these brackets will work.
The small bracket has the hole for the ECU knob. $75 shipped. Attached thumbnail(s) |
jagalyn |
Dec 22 2021, 01:03 PM
True Patina Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None |
These are the two ECU brackets that are used on D Jet engines 1970-74. The 75-76 cars had the bracket spot welded to the front battery tray edge. If you have replaced the battery tray these brackets will work. The small bracket has the hole for the ECU knob. $75 shipped. I will take them. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:51 PM |
