Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,424 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
There is just something about a 914 chassis all bare like that..... (IMG:style_emoticons/default/wub.gif)
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,626 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
frankieshooz |
Member ![]() ![]() Group: Members Posts: 90 Joined: 23-September 14 From: Mill Valley, CA Member No.: 17,945 Region Association: Northern California ![]() |
Been I while since I posted. Here is some updates of the work done over this last year. Enjoy!
Finishing up metal work. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
frankieshooz |
Keep sanding..
frankieshooz |
Primer!
frankieshooz |
Fresh paint!
frankieshooz |
..this is the point I had a hiccup..after understanding I was getting a lot more power/performance with the motor rebuild I thought it would be prudent for me to add an oil cooler. Unfortunately, this realization came after I had it painted the car! So, here we go cutting up some nicely newly painted metal…oops
frankieshooz |
More oil cooler and beyond pics…I was kinda belligerent about not cutting up the front panel of the nose and using the factory holes as my air inlet. I also chose to go with a louvered vented floor panel (not what they usually do) and hard oil lines…maybe not the most efficient way to cool but I liked the look and cleanliness of this method. Thanks for putting up with me (PMB). First pic is of a car I really loved at Lüftgeküllt. If you look close you can see the stock nose holes in this car behind the bumper cutout. last pic is of our esteemed forum contributor (and my advisor) Michaels car, which inspired me to copy this look. Stock with a some teeth showing!
frankieshooz |
Next and current drama…seats….first HUGE SHOUT OUT TO WARD AT VINTAGE SEATS! He has been a true gentleman and first class service and timeliness! If you are looking for aftermarket seats this is the place to go! These are a little more $$$ than some of the other seat builders but they are top notch, perfect fit, and look the business! These are exact replicas of the LeMans winning GT seats. First pic is of Wards standard design…I wanted to do a tartan, specifically, copy Magnus’ 911 seat (second picture). Seats came out great (third picture) but I did not communicate clearly about laying the pattern specifically a certain way, and although subtle, it didn’t come out the way I wanted. NOT WARD’S FAULT! Anyway, seats are back at his shop while I contemplate next move. I am considering doing woven inserts from Achtung Kraft. Pricey. Super unique. Definitely a nod to Singer…also want to add whatever I end up with on the seats to face of the dash but not the door panels…
frankieshooz |
Not to press an already stressful topic but I played around with the fabric…using a seat from my 94 FD3S R2 Mazda..I laid the fabric the two different ways. Can you guys see the difference? Am I batshit crazy? Thoughts on the material or any other suggestions?
Chime in! The last pic is of a woven leather interior. Not the colors (obviously) I would go with for my car but as an idea kind of cool. ![]() ![]() ![]() |
frankieshooz |
..so hope you enjoyed pics..didn’t publish everything but you get the gist..Huge thanks to the guys over at PMB! THANKS ERIC AND CO…
Just ordered the Rennspeed shifter with protostick option. The pedalboard and passenger floorboard with pedal covers along with auxiliary 3 gauge pod (as I plan to eliminate the console and install 3 auxiliary gauges in the dash where the radio would go) from THOROTEC all in anodized black. I am not running back pad or carpet in a the car so everything needs to look finished (I had interior painted to same standard as exterior) Please let me know what you think or questions you have.. |
frankieshooz |
BTW shout out to and big thanks Michael (Cairo 94507) you have been my guiding light and go to guru throughout this build! Thanks for answering all my texts and endless questions! Can’t wait to go for a cruise with you and your amazing 6 although it will be hard for me to keep up with you after you install that new beast of a motor!
SteveL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 664 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None ![]() ![]() |
This is the first time I have read through this thread - one question:
Did you have the car dipped to start with? If so, how did PMB keep it from rusting while doing the metal work? |
Cairo94507 |
@frankieshooz - Thank you for the kind words; my pleasure to discuss 914's always. Your car is looking great. Before you know it you will be behind the wheel enjoying all that work. Can't wait to see it in person. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/beerchug.gif)
frankieshooz |
Steve L, no the car was not dipped. I do believe the car was media blasted. Not sure what media PMB uses but I this is definitely not the first time at the rodeo for them so there is a level of trust that that I have in knowing what they are doing. As far as preventing flash rusting goes I don’t know the answer to that.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,786 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Flash rust shouldn't be a problem in UT. In TX, SC or FL, etc, yes. Touching with bare hands is guaranteed to make bare metal rust no matter the climate. Great work as usual Eric. "You're in Good Hands with..........." , No, that's Allstate. You're in Great Hands with PMB! (IMG:style_emoticons/default/beerchug.gif)
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,589 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
..this is the point I had a hiccup..after understanding I was getting a lot more power/performance with the motor rebuild I thought it would be prudent for me to add an oil cooler. Unfortunately, this realization came after I had it painted the car! So, here we go cutting up some nicely newly painted metal…oops ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sounds like mine, engine scope creep made an after-bodywork-was-finished change needed for a front cooler. PMB should stamp those metal shrouds. Remind me a lot of the one-off Scotty made long ago. LOTS of work if not a stamped part. |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,881 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Not to press an already stressful topic but I played around with the fabric…using a seat from my 94 FD3S R2 Mazda..I laid the fabric the two different ways. Can you guys see the difference? Am I batshit crazy? Thoughts on the material or any other suggestions? Chime in! The last pic is of a woven leather interior. Not the colors (obviously) I would go with for my car but as an idea kind of cool. ![]() ![]() ![]() Seat on right looks better IMHO but what the hell do you like. This is on your dime. In the end you will have spent a large amount of money at PMB. Do what you want to do. I spend a lot of time looking at my PMB 6 build in my cave and that gives me great pleasure. Bob B owner of PMB build of number 41 (IMG:style_emoticons/default/beerchug.gif) |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,073 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Vintage Seats are awesome. I installed a set in a 72 Targa.
burton73 |
I think the price of the Scheels is a bit high. I'm now coming to the "overrated" conclusion. Every Scheel we've been into has been broken or in need of frame repair. They are made rather "cheap" in my book. There's a small welded frame inside and it will not withstand years of using the bolster to get in and out of a 914. Not a big deal if you're going in there and reupholstering the seat. We weld in the repair and we weld in extra frame support to make them work but... all that said, you can easily be upside down in a Scheel. They're gorgeous, don't get me wrong... I just think there's better values out there. Picture of the Scheel seat strip naked by Dale when did the modification to widen it slightly, it looks really bad inside, nasty welding but this boy is 50 years old. Best Bob B ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 1st September 2025 - 07:17 AM |
