> Model Specific Information
> 1974 914 1.8, the mystery of the EC-A and EC-B
wonkipop
post Dec 25 2021, 05:12 PM
i'll be dropping the information we have gathered over Dec 2021 in with a set of posts.
the material was prompted by mr b ( @JeffBowlsby ) who observed that for the 74 MY there was an EC-A and an EC-B engine. mr b's thought was that the EC-A was a 49 states car and and EC-B was a californian car for emissions.
mr b's view was rational and reasoned. 73 EA engines are 49 states. 73 EB engines are california. 75 engines are documented in factory literature as EC-a (49 states) and EC-b (california). the logic should follow?
BUT
as per the mystery of the 914, the truth about 74 1.8s turns out stranger than fiction (or common sense?).
the material is not necessary to running a 1.8 or having fun with a 14. (IMG:style_emoticons/default/smile.gif)
its for historical purposes and as information to 74 1.8 owners to assist with restoration if they want it.
wonkipop
post Dec 25 2021, 10:32 PM
A HYPOTHETICAL.
PAINT STAMP ENGINE NUMBER.
this is a guess at this stage.
the statistical sample of data confirmed is too small for any degree of certainty.
we only have examples of 1 or 2 cars in each case.
# 604 was found on two cars.
both EC-B.
neither car was fitted with a gauge pack/console from new or ordered with the gauge pack/console. (the pack was more normally an option for 2.0 L cars and part of their appearance group option package). the history of one of these cars is well documented and it remains with the second owner.
# 605 was found on one car.
EC-B
the car was fitted with the gauge /console from new.
the history of the car is known from new. it remains with the original owner.
#606 was found on one car.
EC-A
this car was not fitted with gauge/console when sold new.
the car history is known from new and remains with the original purchaser family.
#607 was found on two cars.
EC-A
only one car had sufficient documentation to determine that it was special ordered from the factory with an "app group" option (gauge/console). the car was tourist delivered to the original owner at the karmann factory in germany.
there is one distinguishing feature of 1.8 engines when fully assembled that sets them apart from 2.0 L engines.
1.8 engines came with a standard type second sump lid without provision for a temp
guage sensor and electrical connection unless it was ordered.
all 2.0 engines came with the different second sump lid with the inbuilt sensor and electrical connection.
it was a relatively simple matter to incorporate the gauge and console for the 2.0 either on the production line or at the dealer to suit customer preference.
it was more complex to incorporate gauges for the 1.8 as removal of the sump plate and opening of the sealed engine component with loss of oil was involved. esp so on the production line. (less so at the dealer).
if 1.8s were ordered with the exceptional and unusual option of guage and console this would have to have been allowed for on the production line.
this may have necessitated engine code stamps to ensure correct engine installation.
example of 74 1.8, no gauges/console. second sump lid plate is simple type.
example of 74 2.0, without appearance group option of guages/console.
second sump lid plate is temp sensor type even though gauges not fitted.
this pattern appears to continue for the 1975 MY
example of 75 1.8, no gauges/console. second sump lid plate is simple type.
example of 75 2.0, without appearance group option of gauges/console.
the above examples are vgc and appear to be original cars.
there are two possible ways to test the hypothesis of paint stamp engine numbers further.
1. collect more data on 74 1.8 engines to get a greater statistical sample.
2, expand data collection to 75 1.8 L cars.
if the hypothesis is correct there will be 4 stamped numbers for 75 1.8 cars.
a number for 49 state cars (no gauges).
a number for 49 state cars (gauges)
a number for calif cars (no gauges)
a number for calif cars (gauges)
further, if members with 73 cars were interested.
the guage/console option was on offer in 73.
a possibility is -
for EA engines.
a number for no guage cars.
a number for cars fitted with guages (from new from factory).
for EB engines
= 4 numbers in total.
for 2.0 L cars for 75/76 model years.
it looks to me like the only difference in the cars is whether 49 states or californian.
if the hypothesis is correct (and the only difference between 75/76 2.0 L engines is pollution equipment/specification) there will be two numbers for engine paint stamps for each of the the years.
one for 49 states.
one for california.
73/74 2.0 L cars will have one number for 49 states and california, no difference in emissions spec for those two years?
the exceptions to the above will be engines stamped with EA370 or possibly some other identifying stamp. those stamps appear to identify those engines with the early stage of an engine program connected with cars 73 and beyond. ie the discontinuation of the porsche 6 cylinder engine and the revamping of the engine range towards the 2.0 L and 1.8 L cars. EA370 is the project development # covering that program?
EDIT MAY 2022
further information that has come to light.
for a standard 74 1.8 to be fitted with a console and temp gauge option, in addition to the temp sensor sump lid plate the fully assembled engine would require 3 metal brackets with a crimped end to locate and support the temp sensor wiring clear of the crankcase and oil cooler. these are shown listed 1, 2 & 3 in images below.
1 was incorporated into the original factory sump lid temp sensor housing.
2 was fixed using one of the oil filter housing bolts.
3 was fixed using one of the oil cooler support bracket bolts.
all were not easy to access/fit with the cast fan housing on the assembled engine.
only 914/2.0L engines came with the sump lid plate, temp sensor wire supports and temp sensor wire in place on the assembled engine.
all 914/2.0 L cars were fitted with a temp gauge, either a standard temp gauge in the left hand combo gauge in the instrument binnacle or optioned with the centre console and gauge pack. all 2.0 L engines came with the necessary lid, temp sensor wire and support brackets already fitted.
standard 914/1.8s were not fitted with a temp gauge as standard, but were fitted with a standard wiring loom with provision for a temp gauge. they lacked the temp sensor sump lid, temp sensor wire and support brackets on the assembled engine to make fitting the console a simple plug and play into the wiring loom in the upper engine bay.
914/1.8s could be special ordered with the centre console and gauge pack.
this would have required that the engine was assembled at the VW engine plant with the temp lid, temp sensor wire and brackets in place.
it seems highly likely that the pattern found in existing original cars of:
604 = EC-B engine/car without gauge console.
605 = EC-B engine/car with gauge console.
606 = EC-A engine/car without gauge console.
607 = EC-A engine/car with gauge console.
is the reason for the two different paint stamp engine tin numbers for each of the EC-A or EC-B variants.
608 has been established as the paint stamp number for the 74 AN european spec 1.8 twin carb engine. the car with the 608 engine was not fitted with gauge console.
it is highly likely that a 609 engine existed and this would have been the AN engine fitted to european 1.8s with the gauge console option.
engine tin paint stamp.
1974 1.8 / european spec AN.
held in the collection of the porsche museum germany.
engine stamp # = 608
wonkipop   1974 914 1.8   Dec 25 2021, 05:12 PM
wonkipop   SURVEY OF MEMBERS WITH 74 1.8s. INFORMATION FROM R...   Dec 25 2021, 05:14 PM
wonkipop   DATE - UP DATE OF VAPOR EMISSION CONTROL SYSTEM. ...   Dec 25 2021, 05:19 PM
wonkipop   EC-A and EC-B engines are most obviously identifie...   Dec 25 2021, 05:41 PM
wonkipop   emission stickers indicate that both engine versio...   Dec 25 2021, 05:47 PM
wonkipop   more to come   Dec 25 2021, 06:29 PM
RRietman   more to come If it makes any difference, I shoul...   Dec 25 2021, 07:41 PM
wonkipop   thanks for that info randy i revised the schedule ...   Dec 25 2021, 08:24 PM
wonkipop   EC-A / EC-B THROTTLE BODY AND DISTRIBUTOR WITH VA...   Dec 25 2021, 09:06 PM
wonkipop   EXCEPTIONAL DATA 1 MYSTERY CAR mr. b has documen...   Dec 25 2021, 09:06 PM
wonkipop   EXCEPTIONAL DATA 2 paint stamp engine number EA 3...   Dec 25 2021, 09:43 PM
wonkipop   EXCEPTIONAL DATA 3 EC-A engined car (california/C...   Dec 25 2021, 10:12 PM
wonkipop   A HYPOTHETICAL. PAINT STAMP ENGINE NUMBER. this ...   Dec 25 2021, 10:32 PM
wonkipop   POST SCRIPT A TROUBLED BIRTH FOR L - JET / THE FI...   Dec 25 2021, 11:21 PM
wonkipop   VAPOR EMISSIONS CONTROL SYSTEM. (aka the charcoal...   Dec 26 2021, 12:38 AM
wonkipop   revising comments welcome. further documented 1.8...   Dec 26 2021, 04:02 PM
StarBear   Destined to be a classic (though imho it already i...   Dec 26 2021, 08:07 PM
wonkipop   post script @StarBear of course the 1.8 is a...   Dec 27 2021, 04:54 PM
Van B   Anyone else notice that hellhole rust on the museu...   Dec 29 2021, 02:00 PM
wonkipop   Anyone else notice that hellhole rust on the muse...   Dec 29 2021, 03:57 PM
Van B   Was there any car in the US that got the AN or AT ...   Dec 29 2021, 07:26 PM
wonkipop   Was there any car in the US that got the AN or AT...   Dec 29 2021, 07:46 PM
Van B   Well, really the point is to find high compression...   Dec 29 2021, 10:54 PM
wonkipop   Well, really the point is to find high compressio...   Dec 30 2021, 05:15 PM
JeffBowlsby   AN engine in a factory 1974 914 GT (European-marke...   Dec 31 2021, 10:25 AM
wonkipop   ^ wow. original motor?   Dec 31 2021, 07:04 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 25 2022, 06:12 PM
StarBear   Yep, I'm convinced. Probably (?) not a single ...   Jan 25 2022, 06:39 PM
wonkipop   Yep, I'm convinced. Probably (?) not a single...   Jan 25 2022, 07:24 PM
JeffBowlsby   Nice detective work. I know of nothing in conflic...   Jan 25 2022, 07:15 PM
wonkipop   @StarBear production looks to go like this for 74...   Jan 25 2022, 07:51 PM
L-Jet914   What's interesting is when I replaced my ignit...   Feb 1 2022, 11:17 PM
wonkipop   What's interesting is when I replaced my igni...   Feb 2 2022, 04:12 PM
Van B   @[url=http://www.914world.com/bbs2/index.php?showu...   Feb 20 2022, 11:21 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?show...   Feb 21 2022, 03:39 AM
Van B   I wonder what it sold for? And do you know if the ...   Feb 21 2022, 10:59 AM
wonkipop   I would say we’re it not for a low budget mecha...   Feb 21 2022, 03:41 PM
wonkipop   also that yellow car is one more confirmation that...   Feb 22 2022, 10:25 AM
Racer   What a rather well documented thread. Question.. ...   Feb 22 2022, 02:28 PM
wonkipop   What a rather well documented thread. Question.....   Feb 22 2022, 04:21 PM
Van B   @wonkipop I remember you saying that about the sw...   Feb 25 2022, 11:56 AM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Feb 25 2022, 08:40 PM
Van B   Its got some PoS KYB on the rear and who knows wha...   Feb 27 2022, 11:14 PM
wonkipop   Its got some PoS KYB on the rear and who knows wh...   Feb 28 2022, 02:15 AM
StarBear   Mine has the appearance group, sway bars and the b...   Mar 24 2022, 06:53 AM
wonkipop   for @Van B came across this image in obscure part...   Mar 27 2022, 01:37 AM
wonkipop   VAPOR EMISSION CONTROL SYSTEM update information....   May 22 2022, 01:03 PM
Van B   @wonkipop My car was not a frunk can. It is a re...   May 25 2022, 09:06 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?show...   May 25 2022, 05:02 PM
Van B   Well, it may be inductive reasoning, but given the...   May 25 2022, 05:45 PM
wonkipop   Well, it may be inductive reasoning, but given th...   May 25 2022, 07:20 PM
JeffBowlsby   Wonk, You deserve an award for this charcoal ca...   May 26 2022, 08:52 PM
wonkipop   Wonk, You deserve an award for this charcoal c...   May 27 2022, 03:53 AM
wonkipop   Wonk, You deserve an award for this charcoal c...   May 28 2022, 01:34 AM
wonkipop   After all that research and thanks to all members ...   Jun 5 2022, 01:18 AM
JeffBowlsby   Niiiice. I see that architects hand... :drooley: ...   Jun 6 2022, 06:50 AM
wonkipop   Niiiice. I see that architects hand... :drooley:...   Jun 6 2022, 03:55 PM
StarBear   @wonkipop [b]@[url=http://www.914world.com/bbs2...   Jul 10 2022, 07:59 PM
wonkipop   great stuff @StarBear looks like you guys had a...   Jul 10 2022, 10:03 PM
StarBear   Yep; darn close to pinning it down, I’d say. Gre...   Jul 11 2022, 06:22 AM
StarBear   @rod911964 Rob - Here's the info we were di...   Jul 11 2022, 01:41 PM
wonkipop   @StarBear [b]@[url=http://www.914world.com/bbs2...   Jul 12 2022, 06:29 PM
Van B   Our cars really were like a beta test for the L-Je...   Jul 12 2022, 09:21 PM
StarBear   Our cars really were like a beta test for the L-J...   Jul 13 2022, 02:18 PM
StarBear   Found another 74 (?) this morning behind a garage....   Jul 13 2022, 02:20 PM
wonkipop   came across another plastic expansion tank 74. clo...   Jul 17 2022, 07:04 AM
StarBear   @wonkipop BTW, what color is yours, and what ty...   Jul 18 2022, 06:52 AM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 18 2022, 07:50 AM
wonkipop   just been scratching through my files here a bit m...   Jul 18 2022, 08:02 AM
StarBear   @wonkipop Something special made - for you fro...   Jul 18 2022, 10:46 AM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 18 2022, 04:48 PM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?...   Jul 18 2022, 07:35 PM
StarBear   [quote name='StarBear' post='3016011' date='Jul ...   Jul 19 2022, 06:54 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Jul 18 2022, 05:17 PM
Van B   @wonkipop how many US spec ‘74 1.8s do you thin...   Jul 18 2022, 05:54 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?show...   Jul 18 2022, 06:45 PM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 19 2022, 01:32 AM
Van B   I don’t know how I missed that label lol! Y...   Jul 18 2022, 08:08 PM
wonkipop   I don’t know how I missed that label lol! ...   Jul 18 2022, 08:48 PM
wonkipop   @Van B + [b]@[url=http://www.914world.com/bbs2/i...   Jul 19 2022, 12:12 AM
StarBear   @wonkipop As promised, here's the white font...   Jul 19 2022, 10:44 AM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 19 2022, 03:17 PM
StarBear   "L" is for L-Jet, obviously.....   Jul 19 2022, 10:44 AM
Van B   First off, you two are ridiculous lol... Second, ...   Jul 19 2022, 11:01 AM
StarBear   Good move, Van. My thought is that 1.8s may be th...   Jul 19 2022, 01:06 PM
wonkipop   Good move, Van. My thought is that 1.8s may be t...   Jul 19 2022, 03:14 PM
StarBear   Great! Works for you so go with it. Can apprec...   Jul 19 2022, 07:05 PM
Van B   Well, I straight up missed this page... http://www...   Jul 20 2022, 09:57 AM
wonkipop   Well, I straight up missed this page... http://ww...   Jul 20 2022, 04:37 PM
Van B   Not really. You said you could figure exactly the ...   Jul 20 2022, 05:18 PM
wonkipop   Not really. You said you could figure exactly the...   Jul 20 2022, 05:22 PM
wonkipop   @davep i mentioned in pm that i had also seen an...   Jul 22 2022, 02:00 AM
StarBear   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 22 2022, 05:34 AM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?...   Jul 22 2022, 06:02 AM
wonkipop   new data entered into tables on page 1 of thread. ...   Jul 29 2022, 10:25 PM
StarBear   @wonkipop I’m planning on redoing a sheet of t...   Jul 30 2022, 06:49 AM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 30 2022, 07:07 AM
StarBear   [b]@[url=http://www.914world.com/bbs2/index.php?...   Jul 30 2022, 10:00 AM
wonkipop   [quote name='StarBear' post='3019138' date='Jul ...   Jul 30 2022, 07:11 PM
JeffBowlsby   I was thinking about the charcoal can air supply a...   Aug 5 2022, 06:18 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 16th March 2026 - 12:25 AM
