| wonkipop |
Dec 25 2021, 05:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,513 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
i'll be dropping the information we have gathered over Dec 2021 in with a set of posts.
the material was prompted by mr b ( @JeffBowlsby ) who observed that for the 74 MY there was an EC-A and an EC-B engine. mr b's thought was that the EC-A was a 49 states car and and EC-B was a californian car for emissions. mr b's view was rational and reasoned. 73 EA engines are 49 states. 73 EB engines are california. 75 engines are documented in factory literature as EC-a (49 states) and EC-b (california). the logic should follow? BUT as per the mystery of the 914, the truth about 74 1.8s turns out stranger than fiction (or common sense?). the material is not necessary to running a 1.8 or having fun with a 14. (IMG:style_emoticons/default/smile.gif) its for historical purposes and as information to 74 1.8 owners to assist with restoration if they want it. |
| JeffBowlsby |
Jun 6 2022, 06:50 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,253 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Niiiice. I see that architects hand... (IMG:style_emoticons/default/drooley.gif)
Was the EGR system an overlay to this system for the cars that had it or integrated with it? |
| wonkipop |
Jun 6 2022, 03:55 PM
Niiiice. I see that architects hand... (IMG:style_emoticons/default/drooley.gif) Was the EGR system an overlay to this system for the cars that had it or integrated with it? i did them in the style of your drawing of the 2.0 (IMG:style_emoticons/default/beerchug.gif) a nice way to spend a wet and very cold sunday. dusted off the drawing board. good to get away from the CAD screen. the EGR for calif in 75 was more an integration rather than an overlay. it used the TB of the 74 EC-B to operate the EGR vac valve and it fed the recirculated exhaust into a line that replaced the PCV valve hose with a Y branch metal tube fitting. tells you that the EGR only operated with engine vacuum at steady state part open throttle - ie cruise. to some extent the 75 with EGR (calif) was mimicking the 74 EC-B (49 states car) with vac advance, going for fuel economy and cooler running at cruise. the 75 EC-a 49 states was virtually identical to the 74 EC-A Calif except that the decel vavle was of a different design. which i think explains the mystery of why VW use the upper case A in 74 and lower case in 75. it had us confused if you recall when we started this research last year. you know - how come the 49 states car in 74 was a (B) and then a (a) in 75? similarly the 74 calif is (A) and then a (b) in 75? initially we were all thinking why would they not be consistent using the A and B classification and would apply it to the state/territory the car was equipped for. In an odd way they are consistent. if you consider that the 74 EC-A goes on to be the 75 EC-a and its the layout that is consistent - it just happens to be it fits calif regs in 74 and then complies with 49 states in 75, to more or less the same design. and if you squint with one eye, the 74 EC-B (49 states) kind of goes on to be the prototype of the 75 EC-b (Calif) with the vac advance timing function on distributor transformed into an EGR operated by the same TB port and with the EGR bringing the same benefits in a different way (and more expensive way) as the vac advance. if that makes sense. i think its the best explanation for why the A and B classification get swapped around from 74 to 75 and is altered from upper to lower case. (IMG:style_emoticons/default/confused24.gif) i could probably do some diagrams for 75 if there is another very cold and wet weekend this winter and i need to sit by the heater rather than drive my 914. |
wonkipop 1974 914 1.8 Dec 25 2021, 05:12 PM
wonkipop SURVEY OF MEMBERS WITH 74 1.8s.
INFORMATION FROM R... Dec 25 2021, 05:14 PM
wonkipop DATE - UP DATE OF VAPOR EMISSION CONTROL SYSTEM.
... Dec 25 2021, 05:19 PM
wonkipop EC-A and EC-B engines are most obviously identifie... Dec 25 2021, 05:41 PM
wonkipop emission stickers indicate that both engine versio... Dec 25 2021, 05:47 PM
wonkipop more to come Dec 25 2021, 06:29 PM
RRietman
more to come
If it makes any difference, I shoul... Dec 25 2021, 07:41 PM
wonkipop thanks for that info randy
i revised the schedule ... Dec 25 2021, 08:24 PM
wonkipop EC-A / EC-B THROTTLE BODY AND DISTRIBUTOR WITH VA... Dec 25 2021, 09:06 PM
wonkipop EXCEPTIONAL DATA 1
MYSTERY CAR
mr. b has documen... Dec 25 2021, 09:06 PM
wonkipop EXCEPTIONAL DATA 2
paint stamp engine number EA 3... Dec 25 2021, 09:43 PM
wonkipop EXCEPTIONAL DATA 3
EC-A engined car (california/C... Dec 25 2021, 10:12 PM
wonkipop A HYPOTHETICAL.
PAINT STAMP ENGINE NUMBER.
this ... Dec 25 2021, 10:32 PM
wonkipop POST SCRIPT
A TROUBLED BIRTH FOR L - JET / THE FI... Dec 25 2021, 11:21 PM
wonkipop VAPOR EMISSIONS CONTROL SYSTEM.
(aka the charcoal... Dec 26 2021, 12:38 AM
wonkipop revising comments welcome.
further documented 1.8... Dec 26 2021, 04:02 PM
StarBear Destined to be a classic (though imho it already i... Dec 26 2021, 08:07 PM
wonkipop post script
@StarBear
of course the 1.8 is a... Dec 27 2021, 04:54 PM
Van B Anyone else notice that hellhole rust on the museu... Dec 29 2021, 02:00 PM
wonkipop
Anyone else notice that hellhole rust on the muse... Dec 29 2021, 03:57 PM
Van B Was there any car in the US that got the AN or AT ... Dec 29 2021, 07:26 PM
wonkipop
Was there any car in the US that got the AN or AT... Dec 29 2021, 07:46 PM
Van B Well, really the point is to find high compression... Dec 29 2021, 10:54 PM
wonkipop
Well, really the point is to find high compressio... Dec 30 2021, 05:15 PM
JeffBowlsby AN engine in a factory 1974 914 GT (European-marke... Dec 31 2021, 10:25 AM
wonkipop ^
wow.
original motor? Dec 31 2021, 07:04 PM
wonkipop @[url=http://www.914world.com/bbs2/index.php?showu... Jan 25 2022, 06:12 PM
StarBear Yep, I'm convinced. Probably (?) not a single ... Jan 25 2022, 06:39 PM
wonkipop
Yep, I'm convinced. Probably (?) not a single... Jan 25 2022, 07:24 PM
JeffBowlsby Nice detective work. I know of nothing in conflic... Jan 25 2022, 07:15 PM
wonkipop @StarBear
production looks to go like this for 74... Jan 25 2022, 07:51 PM
L-Jet914 What's interesting is when I replaced my ignit... Feb 1 2022, 11:17 PM
wonkipop
What's interesting is when I replaced my igni... Feb 2 2022, 04:12 PM
Van B @[url=http://www.914world.com/bbs2/index.php?showu... Feb 20 2022, 11:21 PM
wonkipop
@[url=http://www.914world.com/bbs2/index.php?show... Feb 21 2022, 03:39 AM
Van B I wonder what it sold for? And do you know if the ... Feb 21 2022, 10:59 AM
wonkipop
I would say we’re it not for a low budget mecha... Feb 21 2022, 03:41 PM
wonkipop also that yellow car is one more confirmation that... Feb 22 2022, 10:25 AM
Racer What a rather well documented thread.
Question.. ... Feb 22 2022, 02:28 PM
wonkipop
Question..... Feb 22 2022, 04:21 PM
Van B @wonkipop
I remember you saying that about the sw... Feb 25 2022, 11:56 AM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Feb 25 2022, 08:40 PM
Van B Its got some PoS KYB on the rear and who knows wha... Feb 27 2022, 11:14 PM
wonkipop
Its got some PoS KYB on the rear and who knows wh... Feb 28 2022, 02:15 AM
StarBear Mine has the appearance group, sway bars and the b... Mar 24 2022, 06:53 AM
wonkipop for @Van B
came across this image in obscure part... Mar 27 2022, 01:37 AM
wonkipop VAPOR EMISSION CONTROL SYSTEM
update information.... May 22 2022, 01:03 PM
Van B @wonkipop
My car was not a frunk can. It is a re... May 25 2022, 09:06 AM
wonkipop
@[url=http://www.914world.com/bbs2/index.php?show... May 25 2022, 05:02 PM
Van B Well, it may be inductive reasoning, but given the... May 25 2022, 05:45 PM
wonkipop
Well, it may be inductive reasoning, but given th... May 25 2022, 07:20 PM
JeffBowlsby Wonk,
You deserve an award for this charcoal ca... May 26 2022, 08:52 PM
wonkipop
Wonk,
You deserve an award for this charcoal c... May 27 2022, 03:53 AM
wonkipop
Wonk,
You deserve an award for this charcoal c... May 28 2022, 01:34 AM
wonkipop After all that research and thanks to all members ... Jun 5 2022, 01:18 AM
StarBear @wonkipop [b]@[url=http://www.914world.com/bbs2... Jul 10 2022, 07:59 PM
wonkipop great stuff @StarBear
looks like you guys had a... Jul 10 2022, 10:03 PM
StarBear Yep; darn close to pinning it down, I’d say. Gre... Jul 11 2022, 06:22 AM
StarBear @rod911964 Rob - Here's the info we were di... Jul 11 2022, 01:41 PM
wonkipop @StarBear [b]@[url=http://www.914world.com/bbs2... Jul 12 2022, 06:29 PM
Van B Our cars really were like a beta test for the L-Je... Jul 12 2022, 09:21 PM
StarBear
Our cars really were like a beta test for the L-J... Jul 13 2022, 02:18 PM
StarBear Found another 74 (?) this morning behind a garage.... Jul 13 2022, 02:20 PM
wonkipop came across another plastic expansion tank 74.
clo... Jul 17 2022, 07:04 AM
StarBear @wonkipop BTW, what color is yours, and what ty... Jul 18 2022, 06:52 AM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 18 2022, 07:50 AM
wonkipop just been scratching through my files here a bit m... Jul 18 2022, 08:02 AM
StarBear @wonkipop Something special made - for you fro... Jul 18 2022, 10:46 AM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 18 2022, 04:48 PM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?... Jul 18 2022, 07:35 PM
StarBear
[quote name='StarBear' post='3016011' date='Jul ... Jul 19 2022, 06:54 AM
wonkipop @[url=http://www.914world.com/bbs2/index.php?showu... Jul 18 2022, 05:17 PM
Van B @wonkipop how many US spec ‘74 1.8s do you thin... Jul 18 2022, 05:54 PM
wonkipop
@[url=http://www.914world.com/bbs2/index.php?show... Jul 18 2022, 06:45 PM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 19 2022, 01:32 AM
Van B I don’t know how I missed that label lol! Y... Jul 18 2022, 08:08 PM
wonkipop
I don’t know how I missed that label lol! ... Jul 18 2022, 08:48 PM
wonkipop @Van B + [b]@[url=http://www.914world.com/bbs2/i... Jul 19 2022, 12:12 AM
StarBear @wonkipop As promised, here's the white font... Jul 19 2022, 10:44 AM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 19 2022, 03:17 PM
StarBear "L" is for L-Jet, obviously..... Jul 19 2022, 10:44 AM
Van B First off, you two are ridiculous lol...
Second, ... Jul 19 2022, 11:01 AM
StarBear Good move, Van.
My thought is that 1.8s may be th... Jul 19 2022, 01:06 PM
wonkipop
Good move, Van.
My thought is that 1.8s may be t... Jul 19 2022, 03:14 PM
StarBear Great! Works for you so go with it. Can apprec... Jul 19 2022, 07:05 PM
Van B Well, I straight up missed this page...
http://www... Jul 20 2022, 09:57 AM
wonkipop
http://ww... Jul 20 2022, 04:37 PM
Van B Not really. You said you could figure exactly the ... Jul 20 2022, 05:18 PM
wonkipop
Not really. You said you could figure exactly the... Jul 20 2022, 05:22 PM
wonkipop @davep
i mentioned in pm that i had also seen an... Jul 22 2022, 02:00 AM
StarBear
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 22 2022, 05:34 AM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?... Jul 22 2022, 06:02 AM
wonkipop new data
entered into tables on page 1 of thread.
... Jul 29 2022, 10:25 PM
StarBear @wonkipop I’m planning on redoing a sheet of t... Jul 30 2022, 06:49 AM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 30 2022, 07:07 AM
StarBear
[b]@[url=http://www.914world.com/bbs2/index.php?... Jul 30 2022, 10:00 AM
wonkipop
[quote name='StarBear' post='3019138' date='Jul ... Jul 30 2022, 07:11 PM
JeffBowlsby I was thinking about the charcoal can air supply a... Aug 5 2022, 06:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th May 2026 - 07:24 PM |
