| wonkipop |
Oct 29 2025, 11:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
ENGINE BAY BLOWER FAN.
On the data collected to date it appears the engine bay blower fan set up was updated during the course of MY 1975. examples dating from 08/74, 09/74, 10/74 & 11/74 retain the single hose blower fan with a hose feeding to the left hand side heat exchanger only that was used for the 1974 MY. examples dating from 12/74 and on to end of MY production used a revised twin hose blower fan with dual hoses feeding to both the left and right side heat exchangers. the adaptor piece attached to the fan unit appears (based on an extant original example) to have been a VW part used on the 411/412 variant. data collected points to a changeover date late nov 74 or early dec 74. |
| wonkipop |
Oct 29 2025, 11:30 PM
EVAPORATIVE EMISSIONS SET UP.
it has previously been determined that VW & Porsche revised the hose connection set up to the charcoal cannister at the time the cannister was moved to a location on the rear firewall of the engine compartment from its previous location in the front trunk. this ocurred during approx the third week of nov 1973. refer to pg 3 of this topic where the emissions warranties and associated schematic diagrams are traced from 73 MY to 76 MY. the 1975 1.8 L Jetronics used the same hose connection schema as the 74 L jets. the charcoal cannister was repositioned in 1975 directly adjacent to the battery tray. this was possibly done to facilitate space for the EGR valve and plumbing for the california market EF-16 and standardized across both engines. |
| wonkipop |
Oct 29 2025, 11:32 PM
EF-15 & EF-16 VACUUM HOSE DIAGRAMS
Refer to page 3 of this topic for the vacuum hose diagrams for the 1974 L-Jet EC-A and EC-B engines previously published here in 2022. @JeffBowlsby - here are your vac hose diagrams for the 75 L Jets. sorry for the 3 year delay but it took that long to accumulate data that i could trust before i did them. (IMG:style_emoticons/default/biggrin.gif) + i am enjoying a nice lull in arch activities and its spring time - and i felt like drawing. dusted off the drawing board and put away the computer. i sometimes wonder if technology has really taken us into a future whenever i get my old paraline out and a packet of felt tip pens. (IMG:style_emoticons/default/beerchug.gif) |
| L-Jet914 |
Jul 11 2026, 09:52 PM
Member ![]() ![]() Group: Members Posts: 436 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
@wonkipop I found a 74 1.8L hiding on Facebook Marketplace. It has the appearance group package and 607 on the engine tin (right side by cylinder 4 where the evap canister fresh air hose connects.) No vin was pictured.
| wonkipop |
Jul 12 2026, 02:43 PM
@wonkipop I found a 74 1.8L hiding on Facebook Marketplace. It has the appearance group package and 607 on the engine tin (right side by cylinder 4 where the evap canister fresh air hose connects.) No vin was pictured. @L-Jet914 thanks mate. (IMG:style_emoticons/default/biggrin.gif) with all that research we did you sure can spot em now. 607 would be as you say an appearance group car. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) californian delivered too. pity we can't get more info to add to the table of examples. BAT is very good for that. usually gives a trove of info for a car. (IMG:style_emoticons/default/beerchug.gif) |
| wonkipop |
Aug 2 2026, 08:50 PM
a recent topic by a member with a restored 74 2.0 SE brought to light yet another progressive change through MY 74.
windscreen washer bottles. info from the L Jet files suggests 3 types of bottle were used on 74MY 1.8 L Jet cars. 1. white translucent bottle with red (pinkish) screw collar. 2. white translucent bottle with matching white color screw collar. 3. white translucent bottle with blue screw collar. 1.8 L Jets were produced from very late Oct 1973 until June 1974. 1. white translucent bottle - red (pinkish screw collar). only one example on file. a very early 1.8 amongst first off liine. possibly first day of production 30/Oct 73 vin month 11/73. car very original - excellent condition. in terms of L jet cars likely very rare. 2. white translucent bottle - matching white screw collar. a number of examples emerged of this type. they appear to have been restricted to vin month 11/73. November 73. 3. white translucent bottle - blue screw collar. this bottle appears in production month 12/73 and appears to have been used throughout all months after to end of 74 production in 06/74. 12/73 01/74 02/74 1.8 L jet 2.0 Creamsicle 03/74 04/74 05/74 06/74 ![]() |
| wonkipop |
Aug 2 2026, 10:11 PM
eariler in 74 MY (august 73 thru to late oct 73) when the L jet was not yet in production, and USA market 2.0s exclusively came off the line i had a couple of examples but nothing extensive as it is L jets that i have documented.
09/73 74 2.0 red collar. ![]() 10/73 74 2.0 white collar don't have many examples of 2.0 on file to conclude firmly but indication is that red collars may have been used from 08/73 until some time late in oct 73. interestingly this example above of white collar in oct 2.0 matches up with white collars nov 1.8s. but there is one example of a very early red collar 1.8. this probably says that factory went from red collars towards end of oct and into white collar batch and there are a few cars right on the boundary of the changeover that can be either red or white at this time, whether late first "half model year" 2.0s or very early 1.8s. |
| wonkipop |
Aug 2 2026, 10:14 PM
beyond 74 MY --- 75 MY cars.
only have two examples on file of 75 L jet bottles. 11/73 75 1.8 01/75 75 1.8 not enough examples to be conclusive. but highly probable blue collar bottles were used thru 75. EDIT - have trawled through my files further and then searched a little more through BAT for a couple months i did not have. have fleshed out 75 bottles. solid run of blue collar bottles until around 04/75 when bottles with white collars creep back in. 07/74 blue 08/74 blue 09/74 blue 10/74 blue 11/74 blue 12/74 blue 01/75 blue 02/75 blue 03/75 blue 04/75 white. or could be blue. difficult to be sure. 05/75 mixed white + blue blue ![]() white 06/75 no examples found to date. notes - the appearance of white bottles in the few examples i have during 04/75 and 05/75 correlates with the last year 76MY cars. there appears to be a mixture of white and blue bottles used during the short 5 month production run of the last of the cars. - you can also tell from Vin numbers that production on the 75 model year cars slowed down noticeably during the 75 calendar year production. - my hunch is that the factory began to use up remaining parts stocks around this time from early in calendar year 1975 on 75 MY cars until the end of production in december on 76 models. -i have found a few examples of 76 cars spread through the months of production which show this mixture of bottles. will post in a separate addition to the topic. |
| wonkipop |
Aug 2 2026, 10:19 PM
for 73MY, prior to 74 L jets.
2 examples of 1.7 cars from my files. 03/73 73MY 1.7 07/73 73MY 1.7 not enough examples to conclude firmly. but perhaps red collar bottles in use for 73MY. EDIT - further example i dug up from files. 73 MY 1.7 - an extremely early car off the production line. its dated 06/72 on VIN and is 4732900126 - probably second day of production given the Vin #. red bottle. failing a good spread of original condition cars, which i don't have for 1.7s, just a few outstanding examples i filed away in relation to seeing how much changed compared to L jets i'd guess that pretty much all the 73 cars had the red collar bottles, but who knows for sure. (IMG:style_emoticons/default/biggrin.gif) |
| wonkipop |
Aug 12 2026, 06:01 PM
for a laugh and also plain curiosity i kept travelling forward into 1976MY on the water bottle journey.
09/75 white (plain vanilla) 10/75 white 11/75 white, blue, red. 12/75 white, blue looks like they were using whatever was left around in stock and throwing them at the cars randomly depending on the box they opened? also looks to me like this might have been going on as early as the last two months or so of the production of 75MY cars as well as the plain white bottles creep into those cars for the later months of production. |
| wonkipop |
Oct 19 2026, 07:29 PM
@JeffBowlsby and @Starbear
July 1st 1974 1.8s here is some interesting data for you i put together as a result of a recent sale on BAT. two 1.8s with production numbers (karmann plate numbers) that are consecutive. VIN 4742920641 prod (k) number 2719529 VIN 4742920678 prod (k) number 2719528 interesting to see how much further along the VIN number (end of build) is despite both having consecutive production numbers (start of build). 47 cars later. this is the first example i have come across in terms of L jet data which has two cars so close together on start of build dates. (IMG:style_emoticons/default/biggrin.gif) i also picked up an interesting detail which triggered a bit of a trawl through later build 74 1.8s i have on file. i noticed 20641 had later 75MY window winders. ok these could be owner updates - winders known to fail. so i looked up 20678 which i had earlier filed. later 75 style winders too. scanned for others. this is 20850 this one i would definitely be inclined to trust. car belonged to a member here until about 4 years ago. very original unmolested low mileage car. -------- i'm thinking the update to those later style window winders happens right at the end of the 74 MY production run. sometime in june/74. i'd have to have a few more examples on hand to verify this speculation but i'll continue to see what i can find floating around out there when it comes to these last month cars. |
| 914Next |
Oct 22 2026, 07:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest
My survivor 1973 2.0. Car is in storage but found this pic. Looks to be the red collar?
| davep |
Oct 23 2026, 04:14 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,382 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I have quite a few examples of consecutive Karmann body numbers, and many more that are less than 5 apart. Here is one day with significant data:
4742914700 L041 849508 4742914720 L041 849511 4742915176 L041 849519 4742914739 L041 849530 4742914740 L041 849531 4742914970 L80E 849555 4742914980 L80E 849562 4742915585 L80E 849563 4742914979 L80E 849567 4742915640 L80E 849569 As you can see, the VIN does not follow the Karmann number very well. A range of 60 bodies and a range of 940 VIN. I have a hard time keeping up with additions to the database. I need help. |
| wonkipop |
Oct 23 2026, 03:54 PM
I have quite a few examples of consecutive Karmann body numbers, and many more that are less than 5 apart. Here is one day with significant data: 4742914700 L041 849508 4742914720 L041 849511 4742915176 L041 849519 4742914739 L041 849530 4742914740 L041 849531 4742914970 L80E 849555 4742914980 L80E 849562 4742915585 L80E 849563 4742914979 L80E 849567 4742915640 L80E 849569 As you can see, the VIN does not follow the Karmann number very well. A range of 60 bodies and a range of 940 VIN. I have a hard time keeping up with additions to the database. I need help. the k numbers are interesting @davep in the distribution of production line "errors". above i mentioned that the pair of consecutive numbers i found led to an observation that window winders look likely to have been updated prior to the 75 MY. but there was also one other interesting minor detail i picked up which i think was a production line error and is imbedded in both cars. vin 20641 k 2719529 tune up sticker from the engine. this is the tune up sticker for an EC-A california market 1.8 EC-A engines did not have the timing advance hose connected from the distributor to the throttle body port above the throttle plate. the tune up sticker reflected this by showing only one hose to the left of the diagram of the distributor. however this is the paint stamp number on the engine. 605 is the production line code for a 1.8 Ljet EC-B (49 states engine) that was for a car with the appearance group package of gauges and console. the engine came fitted with a sump temp sensor plate and associated wiring factory fitted and ready to connect to the engine bay wiring loom. it also had the throttle body with two ports and both vac line hoses connected to both advance and retard cans on the distributor. the tune up sticker for an EC-B had a hose shown either side of the diagram of the distributor. ------- and this is the other one. vin 20678 k 2719528 tune up sticker. engine production line identification stamp number. its the same spec in terms of engine and option equipment (and even color) wth these two consecutive cars. a EC-B 49 states 1.8 fitted to a car with appearance group option. a 605 engine. and it has the same "error" EC-A california market tune up sticker. (IMG:style_emoticons/default/biggrin.gif) in both cases i do not have sufficient other information to 100% pinpoint the original point of sale. no original documentation or service books included in the sales information with the cars. but both engine bays are in original condition and both cars were in good to fairly good condition. both cars had the dual port throttle body and distributor intact along with the hoses. so i tend to think these are EC-B (49 state cars) that received an incorrect tune up sticker and that the 605 stamp on the engines is correct. unfortunately in both cases the emission sticker in the engine bay was not photographed sufficiently in focus to determine what that sticker was. it could well be that they both got an incorrect EC-A emission sticker as well. i think both these cars which started production one after the other had the same error applied to them at the same moment in time when they reached the point in the line where the stickers were applied. ? |
| davep |
Oct 23 2026, 07:17 PM
Yes, if the painted number does not match the tune-up decal then an error occurred.
Lo-Fi Version | Time is now: 14th November 2026 - 09:02 AM |
