Best adhesive to attach vinyl pieces along dash? |
rosenfe |
Dec 28 2021, 04:09 PM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
Some of the old vinyl is peeling off around glove box, knobs etc. I’ve searched and I haven’t found anything that seems to really work.
dhuckabay |
Dec 28 2021, 04:12 PM
Member Group: Members Posts: 222 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest |
I have had good luck with the 3M spray adhesive, believe it is a contact cement. Got it at Home Depot.
Montreal914 |
Dec 28 2021, 04:32 PM
Senior Member Group: Members Posts: 1,559 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
You might want to watch @iankarr 's video. (IMG:style_emoticons/default/smile.gif)
https://www.youtube.com/watch?v=uP1IA944nyM&t=7s |
iankarr |
Dec 28 2021, 05:11 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Thanks man. Dap/Weldwood landau top contact cement is my go to. Nasty stuff that you'll need a respirator to use...but holds like nobody's business.
bkrantz |
Dec 28 2021, 09:19 PM
914 Guru Group: Members Posts: 7,763 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I also like DAP, and you can find it in spray cans.
VegasRacer |
Dec 28 2021, 11:44 PM
ELVIRA Group: Benefactors Posts: 8,509 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Old school DAP Weldwood contact cement will do the trick.
It stands up to the summer heat in Vegas without losing grip. |
raynekat |
Dec 29 2021, 09:23 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Yes, contact adhesive where you apply it to both pieces and let them dry a bit before placing them together.
76-914 |
Dec 29 2021, 10:53 PM
2nd the Old School Weldwood- now Dap- adhesive. Did you ever notice where it says to stick both pieces together "wet" for permanent installation? (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 04:52 AM |
