Returning Barn Find BB To The Road |
DBF |
Jan 3 2022, 08:00 PM
Member Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I posted earlier about finding this survivor BB and I am working to get it back on the road by spring. I was asked to post more photos, and I’d also appreciate some advice on a couple items.
The first regards the engine. The car has 100K miles, and my experience with VW Type 1 motors is they are ready for a rebuild, at least a top-end rebuild at 100K. Is that true for Type 4's as well? I have the engine stripped down to the bare case/cylinders/heads since I want to clean off 100K worth of old oil/dirt, replace all the oil seals (yes all leaked), and to replace the fuel injection/air intake seals and vacuum lines to help ensure good drivability. Does the mileage say it’s time to keep taking it apart? The second regards the fuel pump. It is still in the rear of course, but I plan to pull the gas tank to replace the old fuel lines, including installing stainless steel lines. “While I’m at it”, should I move the fuel pump to the front? It changes the originality of the car, but I plan to autocross and attend DE events with the car, so looking for safety and reliability. Here is the car on the lift a friend gave me when he closed his auto repair shop this fall. It is a tight fit, but works for my small cars and old jeeps. I was sweating as the lift was being installed, hoping that all my calculations were correct, and was relieved when the 914 fit as planned. I was so anxious to see if it would fit that we lifted the 914 before we cleaned up the garage after the install. It will also allow me to store two small cars. Lastly, while on the lift I can still open and close the 914’s doors with one finger. |
mb911 |
Jan 8 2022, 12:57 PM
914 Guru Group: Members Posts: 6,856 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
JeffBowlsby |
Jan 8 2022, 01:15 PM
914 Wiring Harnesses Group: Members Posts: 8,520 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Here is an example of original fuel lines. This car was incredibly taken care of with tons and tons of maintenance records. I almost have it back together after buying this basket case. The 928 fuel line situation is similar but different than the 914. But your point is well made that both cars are known to burn with fuel leakage from defective or worn out fuel lines. Similar in that both cars rely on rubber soft fuel lines and clamped connections on top of the engine. Different in that the main fuel supply/return lines on the 928 are metal not nylon, and the two primary flex lines are located in very close proximity to the passenger side head. |
Lo-Fi Version | Time is now: 26th May 2024 - 12:57 PM |
