Returning Barn Find BB To The Road |
DBF |
Jan 3 2022, 08:00 PM
Member Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest |
I posted earlier about finding this survivor BB and I am working to get it back on the road by spring. I was asked to post more photos, and I’d also appreciate some advice on a couple items.
The first regards the engine. The car has 100K miles, and my experience with VW Type 1 motors is they are ready for a rebuild, at least a top-end rebuild at 100K. Is that true for Type 4's as well? I have the engine stripped down to the bare case/cylinders/heads since I want to clean off 100K worth of old oil/dirt, replace all the oil seals (yes all leaked), and to replace the fuel injection/air intake seals and vacuum lines to help ensure good drivability. Does the mileage say it’s time to keep taking it apart? The second regards the fuel pump. It is still in the rear of course, but I plan to pull the gas tank to replace the old fuel lines, including installing stainless steel lines. “While I’m at it”, should I move the fuel pump to the front? It changes the originality of the car, but I plan to autocross and attend DE events with the car, so looking for safety and reliability. Here is the car on the lift a friend gave me when he closed his auto repair shop this fall. It is a tight fit, but works for my small cars and old jeeps. I was sweating as the lift was being installed, hoping that all my calculations were correct, and was relieved when the 914 fit as planned. I was so anxious to see if it would fit that we lifted the 914 before we cleaned up the garage after the install. It will also allow me to store two small cars. Lastly, while on the lift I can still open and close the 914’s doors with one finger. |
DBF |
Jan 30 2022, 06:54 PM
I haven't done much on the car this week since I was doing some honey-do projects around the house and converting part of our finished basement to a workshop area. Yes my wife okayed it! I showed some warts on the car on an earlier post (touch up in the trunks, crack in the dash and drivers seat) and here are a couple other warts. Part of the headliner has detached, but fortunately on the edge so should be an easy repair. The bad one is the steering wheel. The original owner glued on a Porsche emblem. I used a heat gun and was carefully pulling it off. It was coming off fairly easily and I was almost done when it popped off and took a bit of the steering wheel with it. I'll try gluing the small piece back, but I suppose worse case is glue the emblem back. It has the same patina as the rest of the car and judging from many photos of other 914's, it was not uncommon for people to add to their cars.
Lo-Fi Version | Time is now: 18th May 2024 - 07:29 PM |
