Injector flow test FAIL ?, Troubleshooting lean condition |
jim-c |
Jan 9 2022, 07:32 PM
Newbie Group: Members Posts: 20 Joined: 21-November 21 From: Fort Lauderdale Member No.: 26,090 Region Association: South East States |
Im working on my recent 914 purchase. 2.0L engine. D-Jet ECU . Intially the engine would fire right up and idle smooth at 1000 rpm. Unfortunately it didn’t want to rev above idle. I could quick pump the throttle and get it to rev but it was undrivable.
I have an AFR gauge and it shows dead lean when i try to rev. I did a flow test on two injectors ( all 4 are new ) . I have 28lbs of FP . Full throttle and crank for 15 seconds yields 2cc per injector. Supposed to be 7 ish. Any ideas ? Nice new harness, MPS holds vacuum and has correct impedance readings. The balance of sensors check out okay with test procedure. Fuel pump holds 28 lbs steady and pumped a quart of gas within 30 seconds . |
emerygt350 |
Jan 10 2022, 05:56 AM
Advanced Member Group: Members Posts: 2,025 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Since you have a 123 and the MPS really can be out of whack and the engine will still run "ok", I think you should a) check your timing (just to be sure) b) check to see that all injectors are firing c) disconnect the throttle switch to see if anything changes d) start to suspect the computer?
Any chance you didn't connect the trigger point wires correctly to the 123? |
Lo-Fi Version | Time is now: 29th March 2024 - 08:58 AM |
