Injector flow test FAIL ?, Troubleshooting lean condition |
jim-c |
Jan 9 2022, 07:32 PM
Newbie Group: Members Posts: 20 Joined: 21-November 21 From: Fort Lauderdale Member No.: 26,090 Region Association: South East States |
Im working on my recent 914 purchase. 2.0L engine. D-Jet ECU . Intially the engine would fire right up and idle smooth at 1000 rpm. Unfortunately it didn’t want to rev above idle. I could quick pump the throttle and get it to rev but it was undrivable.
I have an AFR gauge and it shows dead lean when i try to rev. I did a flow test on two injectors ( all 4 are new ) . I have 28lbs of FP . Full throttle and crank for 15 seconds yields 2cc per injector. Supposed to be 7 ish. Any ideas ? Nice new harness, MPS holds vacuum and has correct impedance readings. The balance of sensors check out okay with test procedure. Fuel pump holds 28 lbs steady and pumped a quart of gas within 30 seconds . |
emerygt350 |
Jan 10 2022, 12:00 PM
Advanced Member Group: Members Posts: 2,067 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
It's a super easy rebuild. I think I got mine from 914rubber. 10 minutes and you are good to go.
The only things that change volume should be duration (the MPS) and the trigger points (dizzy) and the CHT. How do you feel about your CHT? What year is it? I assume you put the FJ67 injectors in it. |
emerygt350 |
Jan 10 2022, 12:03 PM
It's a super easy rebuild. I think I got mine from 914rubber. 10 minutes and you are good to go. The only things that change volume should be duration (the MPS) and the trigger points (dizzy) and the CHT. How do you feel about your CHT? What year is it? I assume you put the FJ67 injectors in it. I am suspect of the throttle switch really contributing though. It should have no effect on static flow on those injectors. It really is just an accelerator pump. It is supposed to tell the system when the car is 'idling' though. I suspect the disconnect just made the computer a little confused and that helped richen the mix (no longer thinks it is idling and is taking information from the MPS at closed throttle). |
Lo-Fi Version | Time is now: 18th April 2024 - 08:58 PM |
