Injector flow test FAIL ?, Troubleshooting lean condition |
jim-c |
Jan 9 2022, 07:32 PM
Newbie Group: Members Posts: 20 Joined: 21-November 21 From: Fort Lauderdale Member No.: 26,090 Region Association: South East States |
Im working on my recent 914 purchase. 2.0L engine. D-Jet ECU . Intially the engine would fire right up and idle smooth at 1000 rpm. Unfortunately it didn’t want to rev above idle. I could quick pump the throttle and get it to rev but it was undrivable.
I have an AFR gauge and it shows dead lean when i try to rev. I did a flow test on two injectors ( all 4 are new ) . I have 28lbs of FP . Full throttle and crank for 15 seconds yields 2cc per injector. Supposed to be 7 ish. Any ideas ? Nice new harness, MPS holds vacuum and has correct impedance readings. The balance of sensors check out okay with test procedure. Fuel pump holds 28 lbs steady and pumped a quart of gas within 30 seconds . |
914Mels |
Jan 10 2022, 01:31 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Im working on my recent 914 purchase. 2.0L engine. D-Jet ECU . Intially the engine would fire right up and idle smooth at 1000 rpm. Unfortunately it didn’t want to rev above idle. I could quick pump the throttle and get it to rev but it was undrivable. I have an AFR gauge and it shows dead lean when i try to rev. I did a flow test on two injectors ( all 4 are new ) . I have 28lbs of FP . Full throttle and crank for 15 seconds yields 2cc per injector. Supposed to be 7 ish. Any ideas ? Nice new harness, MPS holds vacuum and has correct impedance readings. The balance of sensors check out okay with test procedure. Fuel pump holds 28 lbs steady and pumped a quart of gas within 30 seconds . Is the manifold pressure sensor hose clear? Are you getting correct vacuum readings at idle? At idle if you induce a vacuum leak at the pressure sensor hose does that richen up the mixture? |
Lo-Fi Version | Time is now: 23rd April 2024 - 04:22 AM |
