Injector flow test FAIL ?, Troubleshooting lean condition |
jim-c |
Jan 9 2022, 07:32 PM
Newbie Group: Members Posts: 20 Joined: 21-November 21 From: Fort Lauderdale Member No.: 26,090 Region Association: South East States |
Im working on my recent 914 purchase. 2.0L engine. D-Jet ECU . Intially the engine would fire right up and idle smooth at 1000 rpm. Unfortunately it didn’t want to rev above idle. I could quick pump the throttle and get it to rev but it was undrivable.
I have an AFR gauge and it shows dead lean when i try to rev. I did a flow test on two injectors ( all 4 are new ) . I have 28lbs of FP . Full throttle and crank for 15 seconds yields 2cc per injector. Supposed to be 7 ish. Any ideas ? Nice new harness, MPS holds vacuum and has correct impedance readings. The balance of sensors check out okay with test procedure. Fuel pump holds 28 lbs steady and pumped a quart of gas within 30 seconds . |
rhodyguy |
Jan 10 2022, 12:45 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,054 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The fuel sock lives in the bottom of the tank. If not fully fouled, as demand increases delivery decreases. It will suck flat. With a drained tank you can look down the fill opening with a flashlight to see it's condition. The sock should be standing up. Not flattened and laying down. Pumping the tank empty is easy with facet pump, some lengths of fuel line, a battery and a catch container. A BIG catch container.
jim-c |
Jan 11 2022, 10:55 AM
The fuel sock lives in the bottom of the tank. If not fully fouled, as demand increases delivery decreases. It will suck flat. With a drained tank you can look down the fill opening with a flashlight to see it's condition. The sock should be standing up. Not flattened and laying down. Pumping the tank empty is easy with facet pump, some lengths of fuel line, a battery and a catch container. A BIG catch container. Thanks. I will do this today. |
Lo-Fi Version | Time is now: 18th April 2024 - 04:29 PM |
