engine build 1911, modifying the 1800 engine |
duckyde |
Jan 10 2022, 03:24 PM
Newbie Group: Members Posts: 3 Joined: 10-January 22 From: knoxville, tn Member No.: 26,233 Region Association: South East States |
Hi all,
I'm considering building up my stock 1800 into a 1911 and wanted to get some opinions before I pull the trigger. This will be used for street driving and autocross use so I'd still like a smooth idle and road manners. The pistons I found are manufactured by AA, looking online they have mixed reviews and from what I understand are sourced from China. Anyone have any first hand experience with this brand? I then talked to web-cam and they recommended their 00-152 mild street cam. specs are: Valve Lash (Inch): .006" Valve Lift (Inch):0.422 Valve Lift (mm):10.73 Advertised Duration:273° Duration @ 0.050":234° Lobe Center:108° I plan to use my existing weber 40IDF carbs, what jets and venturi size should I use? Has anyone built something like this before? Thanks in advance! |
Lo-Fi Version | Time is now: 18th May 2024 - 05:39 AM |
