Tire sizes, Buying new tires |
pek771 |
Jan 13 2022, 08:39 PM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
Hi all:: I am going to the tire store tomorrow to get my wheels back from having the beater tires removed. The 185/60R15 were good enough to transport the car here from Arizona. These are EMPI 8 spoke, 5.5 W x 15 diameter. Wheels are 4 X 130, I suppose. The car is a 70, no flares, just plain old 4 cylinder config. I am putting a Hyper9 motor in it, and I expect it to come out of corners like a rocket.
What size tires can I fit in the stock wheel wells? The selection is very limited in 195/60R15. But, I can get Hoosiers in 205/50R15. Do the 205 fit? I live in Florida, and will drive the car very infrequently, so I don't care if it has DOT-R tires on it.Nor do I care of speedometer inaccuracies. Thanks! Pat |
brant |
Jan 14 2022, 11:31 AM
914 Wizard Group: Members Posts: 11,626 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Hoosier tires run wider than most other brands
Their attempt to cheat racing rules that specify a specific tire size You’ll find they can be as much as an inch wider that a street tire So the 205 in a Hoosier is not a guarantee fit and would really require a test mount before knowing if it will fit You may need a smaller size or a pulled fender also those wheels are not going to help with a bigger tire. there are 2 different offsets available in those wheels as Kevin mentioned above. one offset is really to fit the VW, and doesn't work well on a 914 you may have the better offset since you had 185's on there... but a stock offset wheel... (similar to the stock rims) will still fit a wider tire than the empi 8 spoke wheel allows.... |
Lo-Fi Version | Time is now: 26th May 2024 - 02:37 AM |
