Continuity Test Results, Help to interpret Continuity Test Results |
MFejsa |
Jan 14 2022, 05:37 AM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Need help to interpret results of continuity test results (see attached) and explain what to do next to get my car running right.
Porsche 914 2.0L 1974 (I believe was originally a 1.7L) My car starts, runs and drives but idles rough and wont rev past 4,000rpm. It hesitates on acceleration. I have changed virtually all components / parts from rebuilt MPS, tested TPS and works, ignition switch, fuel pump, air & cylinder head temp sensor, swapped out ECU to one that was tested to work, and the list goes on. I am posting my continuity test results with the hope that some may have experienced or had the same results and knows what to look into more deeply or can diagnose. The test results concluded the following: 1. When testing the ECU power source from main power relay I could not get the 1V voltage difference from the voltage measured at the battery terminal. No difference and remained the same. Voltage at the battery was 12.79 throughout 2. when testing the voltage at start signal from ignition switch the voltage dropped to 9.7V and was not greater than 12V. However, should be greater than 12V. So, can anyone help, please. I haven't been able to get the car run and drive right since being restored and have run out of options. Regards Michael Attached thumbnail(s) |
Superhawk996 |
Jan 15 2022, 12:02 PM
914 Guru Group: Members Posts: 5,860 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Joining this thread late but I don't see any verification of parts. Maybe I'm missing it (did see the generic comments in 1st post)?
ECU P/n MPS p/n In addition it seems like there was an engine swap or rebuild at one time. Need to verify you have proper parts for the year of FI system -- system is not tolerant of mix and match parts between model years. Per OP previous quote "And not when I pulled the plug wires one at a time didnt not much change at all." There is something wrong . . . . If you pull a plug you should notice a drop in RPM's. Either via ear, increased vibration, or via slight drop on a diagnostic (digital) tach. The three things you must have for an engine to run: Fuel Compression Spark Have you compression checked the engine? With respect to spark -- I do see the coil ohm checks. However, coils are notorious for measuring OK cold but then acting up as they get hot. If you're pulling spark plug wires and not getting a change in RPM's I'd be suspecting poor spark. Likewise someone earlier asked about the plugs. Reply was "new". Once they have been run, they are no longer "new" it is easy to quickly foul out plugs especially if running rich. Likewise, the plug color (ranging from white (lean) to black (rich) and condition (dry, oily, wet with fuel) gives a lot of insight into what is or isn't going on in the combustion chamber. I'd suggest pulling the plugs and posting pictures here. |
MFejsa |
Jan 15 2022, 03:30 PM
ECU - ive also changes the ECU to another which was tested and still have the same outcome.
MPS - was refurbished by reputable individual and recommended highly by most on 914world and it was calibrated to match the engine Not too sure why when I pull the plug there is no different in RPM but others have said that not much RPM change either until you pull 2 plugs. Fuel - Ive replaced fuel pump and its tested at 28-29 psi. Compression - didnt check but purchased from individual who said engine ran fine before shipped. Will check when I get access to tester. With respect to spark the coil is new and also fitted another coil and still same outcome. As for the plugs, I have swapped out to a second set thinking that I may have foul plugs but still same result. I will be checking the valve clearance this week to make sure that its right as I did not do this since fitting the engine. I really appreciate your advice. Will let you know how I go. Regards Michael |
Lo-Fi Version | Time is now: 26th May 2024 - 01:44 PM |
