Continuity Test Results, Help to interpret Continuity Test Results |
MFejsa |
Jan 14 2022, 05:37 AM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Need help to interpret results of continuity test results (see attached) and explain what to do next to get my car running right.
Porsche 914 2.0L 1974 (I believe was originally a 1.7L) My car starts, runs and drives but idles rough and wont rev past 4,000rpm. It hesitates on acceleration. I have changed virtually all components / parts from rebuilt MPS, tested TPS and works, ignition switch, fuel pump, air & cylinder head temp sensor, swapped out ECU to one that was tested to work, and the list goes on. I am posting my continuity test results with the hope that some may have experienced or had the same results and knows what to look into more deeply or can diagnose. The test results concluded the following: 1. When testing the ECU power source from main power relay I could not get the 1V voltage difference from the voltage measured at the battery terminal. No difference and remained the same. Voltage at the battery was 12.79 throughout 2. when testing the voltage at start signal from ignition switch the voltage dropped to 9.7V and was not greater than 12V. However, should be greater than 12V. So, can anyone help, please. I haven't been able to get the car run and drive right since being restored and have run out of options. Regards Michael Attached thumbnail(s) |
emerygt350 |
Jan 14 2022, 05:51 AM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I put a new solid state regulator in mine recently and that fixed low voltage issues I was having. Cheap and easy. Doubt it is the issue though.
What do your spark plugs look like? What kind of injectors are in it (color if you are not sure)? Original distributor? If so, do you have advance and retard? Where are they connected on the throttle body? Is this a stock 2.0 or a built 1.7? |
Lo-Fi Version | Time is now: 5th May 2024 - 11:59 AM |
