Continuity Test Results, Help to interpret Continuity Test Results |
MFejsa |
Jan 14 2022, 05:37 AM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Need help to interpret results of continuity test results (see attached) and explain what to do next to get my car running right.
Porsche 914 2.0L 1974 (I believe was originally a 1.7L) My car starts, runs and drives but idles rough and wont rev past 4,000rpm. It hesitates on acceleration. I have changed virtually all components / parts from rebuilt MPS, tested TPS and works, ignition switch, fuel pump, air & cylinder head temp sensor, swapped out ECU to one that was tested to work, and the list goes on. I am posting my continuity test results with the hope that some may have experienced or had the same results and knows what to look into more deeply or can diagnose. The test results concluded the following: 1. When testing the ECU power source from main power relay I could not get the 1V voltage difference from the voltage measured at the battery terminal. No difference and remained the same. Voltage at the battery was 12.79 throughout 2. when testing the voltage at start signal from ignition switch the voltage dropped to 9.7V and was not greater than 12V. However, should be greater than 12V. So, can anyone help, please. I haven't been able to get the car run and drive right since being restored and have run out of options. Regards Michael Attached thumbnail(s) |
emerygt350 |
Jan 14 2022, 01:38 PM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Just out of curiosity, did you just disconnect the vacuum from the distributor or did you switch to the A setting? I didn't really like the A setting on mine but mine is a 73 so I could switch to the advance setting on the 123. Haven't tried it on the advance setting without the vacuum attached. I suspect it would be little different.
MFejsa |
Jan 15 2022, 02:29 AM
I tried without the vacuum attached on the advanced setting and no different.
Will be playing around with all setting variations today and let you know how I go. But Im hoping that the vacuum line from dizzy connected to retard and on A or B setting will my issue. Thanks again |
Lo-Fi Version | Time is now: 5th May 2024 - 03:40 AM |
