Rennshift with throttle control? |
BillJ |
Jan 14 2022, 02:32 PM
Senior Member Group: Members Posts: 1,091 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
So i purchased the 914 Rubber manual throttle control for the 6 thinking it would be nice to warm up before a track session without minding it personally. However my car has the rennline shifter and therefore no provision for mounting it. Has anyone modded their redline shifter to keep the throttle lever?
mepstein |
Jan 14 2022, 02:58 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I believe 914forme milled a slot in his for the throttle lever. It shouldn’t be hard to just duplicate the factory shifter.
Luke M |
Jan 14 2022, 03:14 PM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
So i purchased the 914 Rubber manual throttle control for the 6 thinking it would be nice to warm up before a track session without minding it personally. However my car has the rennline shifter and therefore no provision for mounting it. Has anyone modded their redline shifter to keep the throttle lever? Are talking about a RennShift Shifter ? Not sure what a redline shifter is. If it's a RennShift unit then yeah I had one modified to fit a factory 914-6 throttle lever. |
930cabman |
Jan 14 2022, 03:19 PM
Advanced Member Group: Members Posts: 3,000 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Is there an "easy" way to add a hand throttle to a 2.0 with twin Webers?
Luke M |
Jan 14 2022, 03:28 PM
Is there an "easy" way to add a hand throttle to a 2.0 with twin Webers? Look here : https://914rubber.com/manual-throttle-actuator-kit-1 |
BillJ |
Jan 14 2022, 03:34 PM
Yes i mean Rennshift. I bought exactly the kit linked from 914 Ribber. @Luke M can you share your design?
930cabman |
Jan 14 2022, 03:40 PM
Is there an "easy" way to add a hand throttle to a 2.0 with twin Webers? Look here : https://914rubber.com/manual-throttle-actuator-kit-1 Thanks, a bit pricey, but I bet we can cobb something up in the shop |
Luke M |
Jan 14 2022, 03:48 PM
Yes i mean Rennshift. I bought exactly the kit linked from 914 Ribber. @Luke M can you share your design? I had RennShift modify the base to fit my factory 6 throttle handle under their base. Check the pics out. I would say see if they could do it for you. Attached image(s) |
RFoulds |
Jan 14 2022, 05:50 PM
Green Teen 66 Group: Members Posts: 836 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
My J West Rennshifter came with the hand throttle slot. And Bruce Stone sold me the hand throttle pieces.
Mark Henry |
Jan 15 2022, 07:59 AM
BillJ |
Jan 15 2022, 08:56 AM
Yes i mean Rennshift. I bought exactly the kit linked from 914 Ribber. @Luke M can you share your design? I had RennShift modify the base to fit my factory 6 throttle handle under their base. Check the pics out. I would say see if they could do it for you. Looks like a fairly straightforward mod. Will call them monday! Thanks folks. |
BillJ |
Jan 15 2022, 11:02 AM
Just saw the tangerine kit. That may be the ticket for me as i dont care about correct really in this case....
JmuRiz |
Jan 15 2022, 11:15 AM
914 Guru Group: Members Posts: 5,423 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I have an early rennshift and the hand throttle on the parts shelf. Good to know they can mill that slot, I might send mine back for the slot (or have a local, with better tools than me, make the slot)
rfinegan |
Jan 15 2022, 02:00 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
IronHillRestorations |
Jan 15 2022, 05:47 PM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Get the one from 914 Rubber, it looks like a good replica of the factory set up, which works go
BillJ |
Jan 15 2022, 07:05 PM
Yeah i have it already but i also have the rennshift installed and the car shifts beautifully so i dont want to mess with that. Its not a must on the list for the February race in Savanah so probably back burner for now
Lo-Fi Version | Time is now: 25th April 2024 - 08:59 PM |
