1.8 Fuel injectors |
JamesJ |
Jan 14 2022, 06:31 PM
Member Group: Members Posts: 220 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hello All,
I need to replace a couple of leaky injectors on my '74 1.8 and wondered if anyone has used an aftermarket injector with success/failure or heard of anyone who has. A knowledgeable friend recommended that I stick with NOS Bosch. Stoddard sells injectors and the salesperson told me that their part number supercedes the Bosch number, but I am unsure about that and they were unable to tell me who manufacturers them or the country of origin. Any thoughts? Thanks, James |
wonkipop |
Jan 14 2022, 09:05 PM
Advanced Member Group: Members Posts: 4,249 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
here is R Atwell's page with the full list of near compatible.
https://www.ratwell.com/technical/Injectors.html 114 and 116 will also work - change the hoses to be right for 914 fuel rail. 914 rubber has hoses. search around as van says. but they are not cheap and not getting cheaper for the nos gear. clay perrine had a tip on nissan injectors i have filed away somewhere. might be cheaper/easier to get hold of (IMG:style_emoticons/default/beerchug.gif) . also where are they leaking from. maybe you can fix the ones you have just with new hoses? |
Lo-Fi Version | Time is now: 28th April 2024 - 05:00 AM |
