Oil capacity for 914-6 conversion, 2.4 |
Dion |
Jan 14 2022, 06:34 PM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Hey Fellas , so I’m getting close to starting my 2.4L. I’ve read that the original 6 takes 9 quarts. Mine is slightly larger as stated. I want to start adding oil to the system. Not only to look for leaks but want to get some in the block so I can rotate her without fear of
scuffing up metal that shouldn’t. I know your supposed to check when hot and running. How much would you add at first. Any starting procedure tips. It is carbed and does NOT have a front cooler. Appreciate any insight and experience. Cheers, Dion Engine porn (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
mb911 |
Jan 14 2022, 07:19 PM
914 Guru Group: Members Posts: 6,838 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
9 qts. Start car and run until 180. Check oil level and top off as needed. This is assuming you have no external oil cooler
Lo-Fi Version | Time is now: 9th May 2024 - 11:19 PM |
