Oil capacity for 914-6 conversion, 2.4 |
Dion |
Jan 14 2022, 06:34 PM
RN Group: Members Posts: 2,762 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Hey Fellas , so I’m getting close to starting my 2.4L. I’ve read that the original 6 takes 9 quarts. Mine is slightly larger as stated. I want to start adding oil to the system. Not only to look for leaks but want to get some in the block so I can rotate her without fear of
scuffing up metal that shouldn’t. I know your supposed to check when hot and running. How much would you add at first. Any starting procedure tips. It is carbed and does NOT have a front cooler. Appreciate any insight and experience. Cheers, Dion Engine porn (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Luke M |
Jan 14 2022, 06:50 PM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
We put 10 qts in my brothers 3.0 6 conv with an org 6 tank. I put some oil in the engine oil cooler before mounting it on the engine. Front oil cooler is not hooked up yet. Seamed to read a little on the high side once we got it running.
Lo-Fi Version | Time is now: 28th April 2024 - 08:00 AM |
