Oil capacity for 914-6 conversion, 2.4 |
Dion |
Jan 14 2022, 06:34 PM
RN Group: Members Posts: 2,762 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Hey Fellas , so I’m getting close to starting my 2.4L. I’ve read that the original 6 takes 9 quarts. Mine is slightly larger as stated. I want to start adding oil to the system. Not only to look for leaks but want to get some in the block so I can rotate her without fear of
scuffing up metal that shouldn’t. I know your supposed to check when hot and running. How much would you add at first. Any starting procedure tips. It is carbed and does NOT have a front cooler. Appreciate any insight and experience. Cheers, Dion Engine porn (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Cairo94507 |
Jan 14 2022, 07:13 PM
Michael Group: Members Posts: 9,716 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I usually put about 9 quarts in my car and then take it for an easy drive to get it hot and make sure the oil cooler thermostat is open and then I checked it and top it off. I would guess about 10 to 11 quarts. I am guessing as I can never really get all of the oil out of the system.
Lo-Fi Version | Time is now: 27th April 2024 - 09:01 PM |
