Oil capacity for 914-6 conversion, 2.4 |
Dion |
Jan 14 2022, 06:34 PM
RN Group: Members Posts: 2,762 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Hey Fellas , so I’m getting close to starting my 2.4L. I’ve read that the original 6 takes 9 quarts. Mine is slightly larger as stated. I want to start adding oil to the system. Not only to look for leaks but want to get some in the block so I can rotate her without fear of
scuffing up metal that shouldn’t. I know your supposed to check when hot and running. How much would you add at first. Any starting procedure tips. It is carbed and does NOT have a front cooler. Appreciate any insight and experience. Cheers, Dion Engine porn (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
worn |
Jan 14 2022, 08:56 PM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I think this is a really good question for anyone who has lost track of how much oil is in a dry sump system. With my 911 and 914-6 I have had oil leaks that could be little or could be large. All I know is that after 30 miles there is evidence of oil spreading out and about. You park, tighten up or otherwise fix the problem. But how much oil remains? I am terrified by the specter of low oil pressure. The net result has been over filling followed by a smoke screen that would do Bond or the US Navy proud.
Guidelines for starting with an unknown oil load would be very very useful for those with dry sumps. |
Lo-Fi Version | Time is now: 27th April 2024 - 05:27 PM |
