Oil capacity for 914-6 conversion, 2.4 |
Dion |
Jan 14 2022, 06:34 PM
RN Group: Members Posts: 2,762 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Hey Fellas , so I’m getting close to starting my 2.4L. I’ve read that the original 6 takes 9 quarts. Mine is slightly larger as stated. I want to start adding oil to the system. Not only to look for leaks but want to get some in the block so I can rotate her without fear of
scuffing up metal that shouldn’t. I know your supposed to check when hot and running. How much would you add at first. Any starting procedure tips. It is carbed and does NOT have a front cooler. Appreciate any insight and experience. Cheers, Dion Engine porn (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Mark Henry |
Jan 15 2022, 08:55 AM
I fill the tank till I can see oil on the dipstick, then it's safe to start. I don't go by the amount it's suppose to take, as you could overfill the tank.
I always run my tank in the lower half of the dipstick marks, never at the full line. I find I have the lowest oil consumption at this mark, less than a liter (quart) per oil change. |
mb911 |
Jan 15 2022, 11:57 AM
914 Guru Group: Members Posts: 6,814 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I fill the tank till I can see oil on the dipstick, then it's safe to start. I don't go by the amount it's suppose to take, as you could overfill the tank. I always run my tank in the lower half of the dipstick marks, never at the full line. I find I have the lowest oil consumption at this mark, less than a liter (quart) per oil change. That is good advice as well. On oil changes I also measure the total amount drained to ensure no over filling. |
Lo-Fi Version | Time is now: 27th April 2024 - 09:47 PM |
