A Tale of Three Calipers, Tell me about different RIBE hardware |
zoomCat |
Jan 16 2022, 12:48 PM
Member Group: Members Posts: 161 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
I'm putting together a pair of rear calipers for a six, which the previous owner had replaced with 911 rears to get the vented disks. He didn't keep the originals, it was back in the 80's and nobody cared.
Here's what I've got so far: On the left is a rebuilt stock 914/6 left rear. The plan is to add a spacer for vented disks. In the middle is a 914/6 right rear, which I got years ago that already has a spacer. It will be rebuilt. On the right is what I think is a right rear Ferrari 308 caliper, because the bleeder is in the wrong place. It can be a donor if absolutely needed. The rears the previous owner had installed are the first candidate for donors. My question today is about the RIBE hardware. On the left is the rebuilt stock, on the right is /6 caliper that had a spacer added. The fasteners on the left have sloped shoulders, while the other has more square shoulders, which I see on the front A and M calipers I've got. What was original, either for the stock calipers or the GT calipers? Is there any functional difference? Esthetically I'd like to get it all matching and correct before I send it all off to PMB, but that depends on availability. |
BillJ |
Jan 16 2022, 01:23 PM
Senior Member Group: Members Posts: 1,094 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Waiting on all 4 of my -6 calipers to arrive from PMB in a couple.days myself. You should ask Eric he will know right away. His expertise on the hardware for these is outstanding.
gandalf_025 |
Senior Member Group: Members Posts: 1,451 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
gandalf_025 |
Jan 16 2022, 01:28 PM
gandalf_025 |
Jan 16 2022, 01:50 PM
914Sixer |
Jan 16 2022, 03:34 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You normally used the hardware that came out of the donor
911 caliper to install spacers |
Jan 16 2022, 04:04 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You normally used the hardware that came out of the donor 911 caliper to install spacers (IMG:style_emoticons/default/agree.gif) I sent PMB some 914-6 calipers and rear M calipers and they sent me back 914-6GT calipers. The non vented M calipers can be used on the back of a 912. |
BillJ |
Jan 16 2022, 07:47 PM
You normally used the hardware that came out of the donor 911 caliper to install spacers (IMG:style_emoticons/default/agree.gif) I sent PMB some 914-6 calipers and rear M calipers and they sent me back 914-6GT calipers. The non vented M calipers can be used on the back of a 912. If you want to send those over to me since it was an error that would be fine (IMG:style_emoticons/default/drunk.gif) |
Eric_Shea |
Jan 16 2022, 09:08 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Factory 914 six calipers had no spacers and used the “button” head M7x50 and 55 Ribe fasteners. (Caliper on the left)
Factory 914-6/GT “prototype” calipers used both the spacers and the fasteners from the new long wheelbase 911 S with vented rotors on the rear. Those fasteners were M7x60 and 65 “cap” head Ribe. (Caliper in the middle) This early spacer was machined not cast and they have rounded edges with machining marks on them. Remember, this was all new for ATE. Everything was solid rotors up to this point. They didn’t have a 60 or 65mm fastener on all previous calipers. These one off (41 off) prototypes used the 911 stuff all around. These cap head fasteners do not look like A-Caliper fasteners. They look like M7 versions of “M-Caliper” fasteners. M-Calipers used a “cap” head M8 fastener. A-Caliper fasteners are actually M9 versions of our 914-6 M7 button head fastener. M7 fasteners have Ribe R5 bit heads. A-Calipers, again, use an M9 version of our “button” head with a Ribe R6 bit head. Probably one of the more delicate fasteners to get apart because of the smaller bit head and larger M9x1 thread engagement. In contrast, the M8 M-Caliper fasteners use the M8 cap head with a much more robust Ribe R8 bit head. Much easier to remove without damaging. The last caliper is a Ferrari 308 caliper. (Bleeder positioned under the handbrake arm). (Caliper on the right) These came from the factory with spacers installed. These would be a cast, more form fit spacer as identified by the casting line running around the spacers. By this time ATE spec’d the proper M7 x60 and 65 button head Ribe fasteners to use on these calipers as this was a production unit. Hope that helps. |
Eric_Shea |
Jan 16 2022, 09:12 PM
Eric_Shea |
Jan 16 2022, 09:19 PM
Eric_Shea |
Jan 16 2022, 09:21 PM
This is a perfect example of a factory GT caliper. Low casting number. Shouldered “cap” head vintage 911 fasteners were used. If you know what you’re looking for you can see the rounded edges on the spacers as they come to the pad cavity. |
Eric_Shea |
Jan 16 2022, 09:23 PM
Then again, you could always make your own hardware and spacers …. These worked well for quite some time.. This is a perfect example of what “NOT” to do (IMG:style_emoticons/default/biggrin.gif) If I recall, we fixed this. (If I’m not wrong, they’re probably now the correct GT calipers pictured above in post #12) Wrong size spacers and wrong size aftermarket fasteners that had no strength and no right to be on a brake caliper. (IMG:style_emoticons/default/wink.gif) |
Eric_Shea |
Jan 16 2022, 09:34 PM
PatMc |
Jan 17 2022, 08:09 AM
Member Group: Members Posts: 119 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
Then again, you could always make your own hardware and spacers …. These worked well for quite some time.. This is a perfect example of what “NOT” to do (IMG:style_emoticons/default/biggrin.gif) If I recall, we fixed this. (If I’m not wrong, they’re probably now the correct GT calipers pictured above in post #12) Wrong size spacers and wrong size aftermarket fasteners that had no strength and no right to be on a brake caliper. (IMG:style_emoticons/default/wink.gif) Might not be anything wrong with the fasteners (aside from the fact that they're too long and look like hell). 170,000psi fasteners are readily available in 1/4-28 thread. A 1/4-28 bolt of this spec will have a tensile strength of 8,340 lbs. We have 4 of those bolts in the caliper...so 16,500 lbs or so combined. With a 38mm piston at 1200psi, caliper is trying to spread (or clamp) with a 2,100lbs of force. Looking at the OEM M7 fasteners, 12.9 strength...they should also be 170,000psi. But the unthreaded shank is necked down smaller than the threads, and only about .020" larger in diameter than the shank of a properly made high grade 1/4-28 bolt. Ate also used the same M7 fastener (differenent lengths) in the 42mm 84-89 911 rear, which at the same 1,200 psi would exert almost 2,600lbs of force. Based on these figures, I'd say a 170,000psi 1/4" fastener would be more than suitable to hold a caliper together properly with 33 or 38mm pistons, and 42mm pistons too. |
BillJ |
Jan 17 2022, 08:14 AM
I told you Eric would know. Just chuckling in amazement at the depth of knowledge and understanding. Good stuff.
gandalf_025 |
Jan 17 2022, 09:37 AM
You recall correctly Eric..
I bought these a few years ago at the Hershey Swap Meet just as shown, they were sitting in a box with other calipers.. They were sent to you immediately and made into the set above.. [/quote] This is a perfect example of what “NOT” to do (IMG:style_emoticons/default/biggrin.gif) If I recall, we fixed this. (If I’m not wrong, they’re probably now the correct GT calipers pictured above in post #12) Wrong size spacers and wrong size aftermarket fasteners that had no strength and no right to be on a brake caliper. (IMG:style_emoticons/default/wink.gif) [/quote] |
Superhawk996 |
Jan 17 2022, 11:47 AM
914 Guru Group: Members Posts: 5,778 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Setting aside the question of fastener tensile strength and suitability for application. If they didn't have the tools and/or couldn't be bothered to trim the fasteners to the proper length, I have to wonder what else they couldn't be bothered to do properly when working on brakes. (IMG:style_emoticons/default/sheeplove.gif) I would never trust my life to workmanship like that. (IMG:style_emoticons/default/slap.gif) |
Eric_Shea |
Jan 17 2022, 09:51 PM
Setting aside the question of fastener tensile strength and suitability for application. If they didn't have the tools and/or couldn't be bothered to trim the fasteners to the proper length, I have to wonder what else they couldn't be bothered to do properly when working on brakes. (IMG:style_emoticons/default/sheeplove.gif) I would never trust my life to workmanship like that. (IMG:style_emoticons/default/slap.gif) Those were a hot mess. Duly noted though that Home Depot fasteners are OK to use on brake calipers. (IMG:style_emoticons/default/biggrin.gif) |
zoomCat |
Jan 18 2022, 04:59 PM
Thanks for all the feedback, Eric in particular for the encyclopedic knowledge of the particulars. It looks like the 60 and 65mm button head fasteners on the Ferrari were never used on the 914/6 GTs, so I don't need to chase down a set of those.
I wouldn't hold up the build for that non-functional distinction, but it's amazing how you can become invested in some of the smallest details when you disassemble a car to every nut and bolt. Now I just have to get the very rusty bleeders out of my donor M calipers. I suspect that the piston bores are not salvageable anyway. |
Lo-Fi Version | Time is now: 5th May 2024 - 11:14 AM |
