WTB Wheel Bolts, American Racing |
pek771 |
Jan 19 2022, 07:09 AM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
Van B |
Jan 19 2022, 06:57 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Post a close up. It’s all washed out because of the matte aluminum
sixnotfour |
Jan 19 2022, 07:44 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
use adapter studs 14 mm to 12x1.5 or 1/2-20 and buy lug nuts ,,summitt racing ,, weld racing lug nuts .. measure the bore on the wheel ..I assume .690
pek771 |
Jan 19 2022, 10:23 PM
This is the wheel before I had it glass beaded. The distinguishing feature of these wheels is the lack of any chamfer or countersink at the wheel bolt holes. Thus, they ran with a heavy washer under a standard bolt.
I was going to countersink the holes to accept a standard US 60 degree taper, with a 14mm bolt. But my drill press is only 5-1/2" deep, where it needs 6"+ to clear the wheel. I hate that. So, I look for bolts. |
Van B |
Jan 19 2022, 11:42 PM
Then they run the same stud and through lug nut that my gurney wheels do.
Sixnotfour laid out what you need. |
Eggman |
Jan 20 2022, 06:28 PM
Newbie Group: Members Posts: 2 Joined: 2-December 21 From: Vernon AZ Member No.: 26,127 Region Association: None |
Anyone in need of a set of four of the same American Racing wheel I have some.
jrmdir |
Jan 21 2022, 11:19 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Van B |
Jan 21 2022, 08:00 PM
My gurney wheels came with studs and shouldered lug nuts vs bolts. Never seen your wheel bolts before. @jrmdir
pek771 |
Jan 22 2022, 04:34 AM
I am assuming Gurney wheels are not the same as these American Racing wheels. These AR wheels have a 14mm hole for the wheel nuts As such, a 0.670 Weld sleeve will not exactly fit well into a 0.556 hole. I am guessing the original AR wheels had a 14mm bolt, with a non-threaded shank in the wheel, and some sort of hardened washer.
I found a bigger drill press. I will countersink the holes with a 14mm radius and be done with it. That way, I can use the same lug bolts. |
jrmdir |
Jan 22 2022, 10:42 AM
Never seen your wheel bolts before. @jrmdir Those were what the wheels came with. There are several threads about them being hard to find now. Also discussions about the wheels being added by dealers back then to jack up the profit. With these bolts there was no need to add studs, void warranties, etc. See posts 9 through 12 here: http://www.914world.com/bbs2/index.php?showtopic=159529 Ron |
914werke |
Jan 24 2022, 04:50 PM
"I got blisters on me fingers" Group: Members Posts: 10,042 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ive got theses? (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 6th May 2024 - 04:32 AM |
