Handling issues - need adjustment advice |
Brian Fuerbach |
Jan 20 2022, 02:57 PM
Member Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. Things get better with a full tank of fuel. Is that just the nature of the 914, full tank factored into weight bias, or can the suspension be tuned to emulate the weight.
Here is what Im working with; -19mm adjustable sway-bar set about 1” back from full soft. -Koni yellow adjustable shocks -Stock front torsions -Rear springs are aftermarket (reddish orange color) but I do not know the poundage. Any input would be appreciated. |
Superhawk996 |
Jan 20 2022, 03:47 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. (IMG:style_emoticons/default/confused24.gif) What you've described is the very essence of understeer. 19mm is a lot of front bar that can lead to understeer. Especially so without a lot of rear spring or rear bar behind it to balance it. (IMG:style_emoticons/default/popcorn[1].gif) |
914_teener |
Jan 20 2022, 03:57 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. (IMG:style_emoticons/default/confused24.gif) What you've described is the very essence of understeer. 19mm is a lot of front bar that can lead to understeer. Especially so without a lot of rear spring or rear bar behind it to balance it. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/agree.gif) Stock bar is more than enough. Think also it is alignment and oversprung on the front end. |
Superhawk996 |
Jan 20 2022, 05:01 PM
Stock bar is more than enough. Think also it is alignment and oversprung on the front end. I'm with you that there could be some alignment issue embedded in this but he's on stock torsion bars so not oversprung with big 21mm torsion bars or something like that. These things are always hard to sort out based on words since handling is so subjective. Once man's balanced neutral handling is another's oversteeer or understeer. The fact that it varies with fuel load is very typical of 914 handling with the inherent understeer improved at full tank or lugage loading. It could also be a symtom of what Freezin referenced, front end sitting too high and the fuel load brings the geometry back toward what it ought to be. Keep in mind 914 track width is asymetric (narrower in front) with a design intent toward keeping a stock car biased toward understeer which is the "safe" design parameter. Further staggering tire widths toward wider rear & narrow front can further push this bias deeper into understeer. Not saying that is the case here since there was no mention of tire sizes (I'm assuming same widths front & rear at this point). |
Lo-Fi Version | Time is now: 16th May 2024 - 11:35 PM |
