Handling issues - need adjustment advice |
Brian Fuerbach |
Jan 20 2022, 02:57 PM
Member Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. Things get better with a full tank of fuel. Is that just the nature of the 914, full tank factored into weight bias, or can the suspension be tuned to emulate the weight.
Here is what Im working with; -19mm adjustable sway-bar set about 1” back from full soft. -Koni yellow adjustable shocks -Stock front torsions -Rear springs are aftermarket (reddish orange color) but I do not know the poundage. Any input would be appreciated. |
brant |
Jan 20 2022, 03:29 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Does the rear come around or just a front push?
Any rear sway? You did not mention a 4 wheel alignment after the components were installed? You can usually dial push out. No matter the fuel level Anything else??? Limited slip? |
Brian Fuerbach |
Jan 20 2022, 05:08 PM
Does the rear come around or just a front push? Any rear sway? You did not mention a 4 wheel alignment after the components were installed? You can usually dial push out. No matter the fuel level Anything else??? Limited slip? Rear is planted and never feels loose. Front just feels like it is not biting the corner. After I installed the swaybar it did make the car much better all around. Front had been aligned by previous po but I have no paperwork. An alignment at a shop that know what they are doing will be next. No limited slip |
Lo-Fi Version | Time is now: 17th May 2024 - 06:15 PM |
