Handling issues - need adjustment advice |
Brian Fuerbach |
Jan 20 2022, 02:57 PM
Member Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. Things get better with a full tank of fuel. Is that just the nature of the 914, full tank factored into weight bias, or can the suspension be tuned to emulate the weight.
Here is what Im working with; -19mm adjustable sway-bar set about 1” back from full soft. -Koni yellow adjustable shocks -Stock front torsions -Rear springs are aftermarket (reddish orange color) but I do not know the poundage. Any input would be appreciated. |
Superhawk996 |
Jan 20 2022, 03:47 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. (IMG:style_emoticons/default/confused24.gif) What you've described is the very essence of understeer. 19mm is a lot of front bar that can lead to understeer. Especially so without a lot of rear spring or rear bar behind it to balance it. (IMG:style_emoticons/default/popcorn[1].gif) |
914_teener |
Jan 20 2022, 03:57 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. (IMG:style_emoticons/default/confused24.gif) What you've described is the very essence of understeer. 19mm is a lot of front bar that can lead to understeer. Especially so without a lot of rear spring or rear bar behind it to balance it. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/agree.gif) Stock bar is more than enough. Think also it is alignment and oversprung on the front end. |
Brian Fuerbach |
Jan 20 2022, 05:26 PM
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. (IMG:style_emoticons/default/confused24.gif) What you've described is the very essence of understeer. 19mm is a lot of front bar that can lead to understeer. Especially so without a lot of rear spring or rear bar behind it to balance it. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/agree.gif) Stock bar is more than enough. Think also it is alignment and oversprung on the front end. Can larger rear springs be installed to balance? |
Lo-Fi Version | Time is now: 16th May 2024 - 10:28 PM |
