Handling issues - need adjustment advice |
Brian Fuerbach |
Jan 20 2022, 02:57 PM
Member Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. Things get better with a full tank of fuel. Is that just the nature of the 914, full tank factored into weight bias, or can the suspension be tuned to emulate the weight.
Here is what Im working with; -19mm adjustable sway-bar set about 1” back from full soft. -Koni yellow adjustable shocks -Stock front torsions -Rear springs are aftermarket (reddish orange color) but I do not know the poundage. Any input would be appreciated. |
Superhawk996 |
Jan 20 2022, 03:47 PM
914 Guru Group: Members Posts: 5,826 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. (IMG:style_emoticons/default/confused24.gif) What you've described is the very essence of understeer. 19mm is a lot of front bar that can lead to understeer. Especially so without a lot of rear spring or rear bar behind it to balance it. (IMG:style_emoticons/default/popcorn[1].gif) |
Brian Fuerbach |
Jan 20 2022, 05:24 PM
When driving large sweepers like freeway on ramps at high speed I experience what I can only describe as front end scrubbing. Not understeer, more like the front is just not planted and tracking. (IMG:style_emoticons/default/confused24.gif) What you've described is the very essence of understeer. 19mm is a lot of front bar that can lead to understeer. Especially so without a lot of rear spring or rear bar behind it to balance it. (IMG:style_emoticons/default/popcorn[1].gif) I guess it is possible that if I pushed it harder it could turn into noticeable oversteer but it just does not feel like understeer that I have experienced before. Need find out what springs are in the rear now. Can you tell by diameter? I used to drive this on the street, talk about oversteer. (IMG:style_emoticons/default/evilgrin.gif) (correction: "Understeer") Attached thumbnail(s) |
Superhawk996 |
Jan 20 2022, 05:53 PM
I used to drive this on the street, talk about oversteer. (IMG:style_emoticons/default/evilgrin.gif) Please don't take this the wrong way. I'm trying to help. Honestly. I've done chassis tuning as my day job for a decent part of my professional career as a chassis engineer. That buggy by definition will have steady state understeer. Beam front axle without camber gain, wide rear tires, narrow font tires, lack of weight on the front tires. I don't think we aren't talking the same terms. I do agree the buggy could have massive lift throttle oversteer at initial turn-in due to the inherent rear weight bias. Likewise, it could develop on-throttle oversteer with enough horsepower. Both of those are transient conditions. As I understood your original post, we are talking steady state condition, after you've entered the corner, steady state throttle, and the front end isn't tracking. You're putting in more and more steering input to the point that you feel the tires are scrubbing but yet it's not turning or following your steering input. Do I understand correctly? |
Lo-Fi Version | Time is now: 18th May 2024 - 03:05 AM |
