anyone made their own door panels?, Don't want to spend $$$ if I can duplicate the old pressboard |
914Mels |
Jan 21 2022, 05:03 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
I'm continuing the interior rebuild, moving on to the door panels. The old ones are pretty basic construction, press board, foam and vinyl. The press board is shot after fifty years plus the big hole for a door speaker I'm not putting back in. I can get the board for cheap at HomeDepot so I plan to trace the old ones and try my luck. I'm not worried about durability so much as the car never sees rain so If I can duplicate them so much the better. One thing I noticed, the vinyl is sewn together at the bolster but the vinyl I see for sale shows two separate pieces. There is a channel they tuck into so how do you hold em together?
vintagethunder |
Feb 5 2022, 06:22 PM
Newbie Group: Members Posts: 38 Joined: 7-January 22 From: Monmouth, IL Member No.: 26,225 Region Association: Upper MidWest |
There is waterproof door card material out there now. I don’t know, but I would think it should become the go-to material for the industry. I'm hoping an auto upholstery shop will sell some to me. I have not been able to nail down if it is a waterproof treatment on the surface or if it is all the way through. Hopefully the shop can tell me. I have seen where some treat the holes for the snaps in door card with superglue for strength, as the panels can be popped on and off several times during the life of the material.
I’m also assuming the foam being used these days is closed cell instead of the water absorbing foam rubber used in the past. Has Scotch 77 spray adhesive replaced staples? |
Costa05 |
Feb 5 2022, 07:57 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
There is waterproof door card material out there now. I don’t know, but I would think it should become the go-to material for the industry. I'm hoping an auto upholstery shop will sell some to me. I have not been able to nail down if it is a waterproof treatment on the surface or if it is all the way through. Hopefully the shop can tell me. I have seen where some treat the holes for the snaps in door card with superglue for strength, as the panels can be popped on and off several times during the life of the material. I’m also assuming the foam being used these days is closed cell instead of the water absorbing foam rubber used in the past. Has Scotch 77 spray adhesive replaced staples? Foam for me was same used on car headliners. Upholstery shop grade, 1/4" thick IIRC. And yes high temp pro quality spray adhesive. |
Lo-Fi Version | Time is now: 20th September 2024 - 07:31 PM |
