Correct spark plug wires for 2.0 engine |
Lockwodo |
Jan 23 2022, 01:05 PM
Member Group: Members Posts: 201 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
Hi all. I need to get some new spark plug wires and have noticed that on some sets, two of the spark plug end insulators are longer than the other two insulators. And I've seen other sets where the insulator lengths are the same for all four cylinders. Which is correct for the 2.0 engine?
I did see one post on this forum saying that the plug wire insulator lengths should be the same for all four wires for the 2.0 engine but different lengths for the 1.7 and 1.8 engines. By the way, I bought a set of Denso wires but found that the #1 plug wire was not long enough to comfortably reach from the plug to the disty. |
Lockwodo |
Jan 25 2022, 08:37 AM
Well, I answered my own question with a little research. The "correct" ignition wires for a 2.0 will have equal length insulators on all four spark plug wires, whereas ignition wires for 1.7s and 1.8s have the two longer insulators. It seems like the unequal insulator length wires are what you'll end up with for your 2.0 if you just go with what most of the parts houses want to sell to you. They work but hey, who needs the extra weight (IMG:style_emoticons/default/WTF.gif)
Shivers |
Jan 25 2022, 08:44 AM
Senior Member Group: Members Posts: 2,400 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Pelican and other parts houses that are used to dealing with type 4's will get it right.
Lockwodo |
Jan 25 2022, 09:13 AM
Yes, Auto Atlanta also got it right on this one.
JFJ914 |
Jan 25 2022, 12:50 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Use 1976 912E 2.0 wires
steuspeed |
Jan 25 2022, 02:38 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Note: If you buy oversized wires, they won't fit on the engine tin wire clips.
930cabman |
Jan 25 2022, 03:08 PM
Advanced Member Group: Members Posts: 3,099 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Is anybody making their own?
Lo-Fi Version | Time is now: 26th May 2024 - 11:58 PM |
