Front sway bar mounts |
TRS63 |
Jan 25 2022, 07:53 AM
Member Group: Members Posts: 316 Joined: 14-September 20 From: Germany - Stuttgart Member No.: 24,690 Region Association: Europe |
Hello together,
I bought what was supposed top be a complete front sway bar for my 914. As the tank is out, that would be a great time to mount it! But what I have is pretty strange, with welded screws instead of welded nuts: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-24690-1643118779.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-24690-1643118780.2.jpg) Is it then supposed to be welded like that, or from the inside, or it just doesn't work on the 914? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.thesamba.com-24690-1643118780.3.jpg) Thanks! Antoine |
TRS63 |
Jan 25 2022, 08:35 AM
Ok perfect! Then I will just mount it like original with cutting/welding back the frame extention. No to find the drawing with the positions of the holes (IMG:style_emoticons/default/smile.gif)
Antoine |
Superhawk996 |
Jan 25 2022, 08:56 AM
914 Guru Group: Members Posts: 5,869 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Ok perfect! Then I will just mount it like original with cutting/welding back the frame extention. No to find the drawing with the positions of the holes (IMG:style_emoticons/default/smile.gif) Antoine If you're in a hurry since it's already afternoon in Germany, you can basically eye ball it based on the wheelhouse stamping formation. Maybe drill a 1/8" test hole, make sure it high enough to have the ARB clear the "frame" without rubbing? I'll grab a few measurements later tonight to help you properly locate the ARB main hole if you want a more certain location. |
Lo-Fi Version | Time is now: 27th May 2024 - 09:24 PM |
