What is best tool to get oil filter out |
rosenfe |
Jan 25 2022, 11:26 AM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
I’ve tried various cup like tools, but they are either to big or small. Ian karr has one in his video that looked good. Not sure where he got it. What do you guys use?
yeahmag |
Jan 25 2022, 11:40 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I like this style:
https://www.amazon.com/TEKTON-5866-12-Inch-...sr=8-6&th=1 I have the 3 jaw ones too that I use sometimes. Something like this: https://www.amazon.com/Milliontronic-Oil-Fi...132&sr=8-28 |
jrmdir |
Jan 25 2022, 11:42 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
The TEKTON pliers worked well for me also.
Ron |
JeffBowlsby |
Jan 25 2022, 12:07 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Large channel locks
brubou |
Jan 25 2022, 12:13 PM
Bruce Bouchard Group: Members Posts: 92 Joined: 29-February 16 From: West Bradford, PA Member No.: 19,716 Region Association: MidAtlantic Region |
Mark Henry |
Jan 25 2022, 12:26 PM
iankarr |
Jan 25 2022, 12:33 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Links to the tools shown in the video are in the Youtube description pane. You may need to open it up. I get no benefit from purchases (IMG:style_emoticons/default/wink.gif).
Shivers |
Jan 25 2022, 01:28 PM
Senior Member Group: Members Posts: 2,368 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
When all else fails, I put the oil pan under it and hammer a screw driver through it. Turn clockwise
Dredwin |
Jan 25 2022, 01:51 PM
Member Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains |
When all else fails, I put the oil pan under it and hammer a screw driver through it. Turn clockwise You have to be careful doing it this way...the first time I tried to remove the filter with various wrenches failed and I tried this...only to fail and have a car with no oil and a stuck filter. I ended up getting one of those removal tools that has a chain and it compressed the busted filter quite a bit. I had to wrap it around as close to where it attached to the engine and cursed up a storm to get it off. Ironically, my daughter did the same thing when she overtightened her filter and she used a screwdriver without talking to me first). In my defense, the prior owner also was unable to remove the filter so it wasn't me that tightened it. |
Geezer914 |
Jan 25 2022, 05:19 PM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Use K&N filters with a 1" nut welded to the bottom.
76-914 |
Jan 25 2022, 06:55 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
This won't help you remove it; this time. Do this and you will never fight one again. Buy a small tube of 100% silicone grease. Found in most hardware and plumbing supply houses. Smear the gasket with a thin layer then screw the filter back on. That's it! An old A&P taught me that several years back. You haven't lived until you try to remove an oil filter from the rear of a Lycoming engine. (IMG:style_emoticons/default/wacko.gif)
bkrantz |
Jan 25 2022, 08:15 PM
914 Guru Group: Members Posts: 7,749 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Over the years I have used all kinds, but seem to use the strap type the most. I can almost always find a position for access and clearance to swing the handle enough to start the filter turning.
https://www.amazon.com/ARES-56046-Wrenches-...708821&th=1 |
Lo-Fi Version | Time is now: 5th May 2024 - 10:27 AM |
