FS Replated door striker sets, 4 late and 2 early sets with new screws |
bdstone914 |
Jan 25 2022, 11:43 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have two early amd four late pairs of door striker plates.
They have been replated in brite clear zinc. New stainless screws and lick washers are included. The late strikers have new rubber stoppers installed. The late sets have the flange to stop the door from being pushed past the striker in the event of a side impact. These changed from the early strikers without the flange. The change happened when they added the impact reinforcements inside of the doors. The late strikers can be used on any year car. The only reason to use the early strikers is if you want to be originally correct. $50 a set for the late an $40 a set for a pair. Attached thumbnail(s) |
jettonjoshua |
Jan 27 2022, 10:14 PM
Newbie Group: Members Posts: 14 Joined: 25-February 08 From: SF Bay Area Member No.: 8,748 Region Association: Northern California |
[quote name='bdstone914' date='Jan 25 2022, 09:43 AM' post='2977324']
I have two early amd four late pairs of door striker plates. They have been replated in brite clear zinc. New stainless screws and lick washers are included. The late strikers have new rubber stoppers installed. The late sets have the flange to stop the door from being pushed past the striker in the event of a side impact. These changed from the early strikers without the flange. The change happened when they added the impact reinforcements inside of the doors. The late strikers can be used on any year car. The only reason to use the early strikers is if you want to be originally correct. $50 a set for the late an $40 a set for a pair. [/quote I'll take a late set, PM sent. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:11 PM |
