Rear trunk hinge pivot question, How do I fix this...? |
mgarrison |
Jan 25 2022, 01:00 PM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Hello 914World Wise Men/Women!
I'm unsure what I need to do to correct this issue with my trunk hinge pivot on the passenger side; The drivers side pivot is tight in its mount that is attached to the body. The passenger side is loose, and just falls out. I'm not sure if it was originally pressed in, or...? Here's the driver's side: But the passenger side is loose, and just sort of falls out of the mount: If someone can provide some direction on how to fix the passenger side, I would greatly appreciate it! (IMG:style_emoticons/default/pray.gif) |
Olympic 914 |
Jan 25 2022, 02:06 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
They were spot welded on the back.
Clean it up and put a couple welds around the edge. Much easier fix than a broken mount. |
mgarrison |
Jan 25 2022, 02:19 PM
Thank you Sir! (IMG:style_emoticons/default/welder.gif)
NARP74 |
Jan 25 2022, 02:44 PM
Senior Member Group: Members Posts: 1,062 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
And if you can't do that, JWest has a retrofit bracket kit.
Lo-Fi Version | Time is now: 11th May 2024 - 05:29 AM |
