Rear trunk hinge pivot question, How do I fix this...? |
mgarrison |
Jan 25 2022, 01:00 PM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Hello 914World Wise Men/Women!
I'm unsure what I need to do to correct this issue with my trunk hinge pivot on the passenger side; The drivers side pivot is tight in its mount that is attached to the body. The passenger side is loose, and just falls out. I'm not sure if it was originally pressed in, or...? Here's the driver's side: But the passenger side is loose, and just sort of falls out of the mount: If someone can provide some direction on how to fix the passenger side, I would greatly appreciate it! (IMG:style_emoticons/default/pray.gif) |
NARP74 |
Jan 25 2022, 02:44 PM
Senior Member Group: Members Posts: 1,061 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
And if you can't do that, JWest has a retrofit bracket kit.
Lo-Fi Version | Time is now: 10th May 2024 - 07:33 AM |
