Parts Alert: USED Steel Upper Steering Bearing Bushing, On Ebay |
914Sixer |
Jan 25 2022, 03:25 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
IF you have one of the plastic entered bushing in your steering column, you can use the VW Beetle one as a replacement. Place steel bushing on shaft, then run upper bearing to to shaft. Snug up bearing to shaft. Steel bushing lip goes to the inside to act as a stop.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 29th April 2024 - 08:14 AM |
