Trunk adjustment, One side higher than other |
Robarabian |
Jan 25 2022, 10:37 PM
914 A Roo Group: Members Posts: 591 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
How do I adjust this so it is even. The hinges all work great and are not cracked / fractured. After my repaint I mounted everything but one side is off.
Is it the adjustment of the hinge hardware (all the little brackets / washers?) Any help is appreciated. |
Robarabian |
Jan 26 2022, 02:38 PM
bump
Superhawk996 |
Jan 26 2022, 02:49 PM
914 Guru Group: Members Posts: 5,769 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Could be a lot going on there.
Assuming trunk hinges are in the right location . . . does it fit better with a gentle twist? Hard to tell from picture is this all lined up along all other sides but this is just excessive gap in Z height? Do you have the seals in there? Is one side seal sitting tall, holding up the right side? Not sure what you mean by "all the little brackets". The little 2nd leg that extends down to the wheelhouse doesn't control Z height. Did it fit properly before paint? |
Olympic 914 |
Jan 26 2022, 04:54 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Do you have the rubber adjusting nubs in the corners set right?
Passenger side may need screwed in more. |
Mikey914 |
Jan 26 2022, 05:11 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Well, looks like trunk lock not installed. I suspect that once it is and the nubs are adjusted correctly, it should be fine.
rhodyguy |
Jan 26 2022, 05:40 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Good eye Mark. Totally missed it.
bkrantz |
Jan 26 2022, 08:29 PM
914 Guru Group: Members Posts: 7,742 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
If all the stuff mentioned above checks out, and if your karma is feeling VERY positive, you might try twisting the trunk lid a bit while it is open about a foot.
Robarabian |
Jan 26 2022, 09:37 PM
Thanks everyone. Yes I installed the rubber seal. I will try to install the lock this weekend and see what happens. Yes, before I took it all apart for paint, it was lined up. So maybe I need to play with the hinges a bit and make sure they are aligned well.
I like all the suggestions and Will report back if I get it right. |
76-914 |
Jan 26 2022, 10:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Luv that color! (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 2nd May 2024 - 09:16 PM |
